My God, you have no clue do you. What jet is in there and what does the plug look like?abreen89 wrote:Alright which # jets do u recomend?Bear45-70 wrote:You have to up jet. The screw only effect idle.abreen89 wrote:Ok guys i gott her running heat cycled and two tanks of premix through her. But no that i can go wot she seems to be running a little lean and hot.. i did a plug chomp and confirmed it on wikispreedia. can i just upjet? or will carb screw tuning fix it?
My 85' spree does run.. but needs some work...
Re: My 85' spree does run.. but needs some work...
well according to wikispreedia my plug is in the good section. REMEMBER IM NEW if you read the jet threads down in looks like a 68 obviously threads up 89. The problem im having is it lags at full throttle and when i go fulll throttle for 1/4 mile it dies this happened twice i removed the gas cap and put back on to see if it was a suction thing and it wasnt. so i walked it back to the garage and inspected the spark plug looked good to me (which isnt saying alot). put it back in and she fired up again. so not quiet sure whats wrong ive just been tuning the carb the best i can but that obviously isnt the problem. let me know thanks!
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock In The Works
Unless you did the plug chop at WOT you plug read is useless.abreen89 wrote:well according to wikispreedia my plug is in the good section. REMEMBER IM NEW if you read the jet threads down in looks like a 68 obviously threads up 89. The problem im having is it lags at full throttle and when i go fulll throttle for 1/4 mile it dies this happened twice i removed the gas cap and put back on to see if it was a suction thing and it wasnt. so i walked it back to the garage and inspected the spark plug looked good to me (which isnt saying alot). put it back in and she fired up again. so not quiet sure whats wrong ive just been tuning the carb the best i can but that obviously isnt the problem. let me know thanks!
alright i do one in the morning and post thanks bearBear45-70 wrote:Unless you did the plug chop at WOT you plug read is useless.abreen89 wrote:well according to wikispreedia my plug is in the good section. REMEMBER IM NEW if you read the jet threads down in looks like a 68 obviously threads up 89. The problem im having is it lags at full throttle and when i go fulll throttle for 1/4 mile it dies this happened twice i removed the gas cap and put back on to see if it was a suction thing and it wasnt. so i walked it back to the garage and inspected the spark plug looked good to me (which isnt saying alot). put it back in and she fired up again. so not quiet sure whats wrong ive just been tuning the carb the best i can but that obviously isnt the problem. let me know thanks!
alright u chopped the plug at WOT (25mph) and it is number 18 on the wikispreedia guid which is in the good section.
Compression was 105 psi tested 3 times and with my air compressor (HF gauge)
The problem- At WOT i can do about 1/2 a mile then when i start going up a slight incline engine dies so i wheel is back home and spray some premix in the air cleaner and she starts right up. So i think its carb issue...
- martynkim
Did you install the jet that was included in the kit? Really now, I understand new :craz
y: but.
- Trafficjamz
Do you have an air box yet?
yes the back is totaly stock now aire box new airfilter. The top end kit is a 49cc (stock size) and tazland didnt say anything about a jet so i have been running the standard 68 jet.
- Trafficjamz
check your tank filter for rust.
- martynkim
Trafficjamz wrote:check your tank filter for rust.
I agree, new fuel lines?
I thought you had a BBK from Taz. Then you would have got a jet.
im running clear lines with inline filter everything seems to be flowing to the carb fine..
- martynkim
Crack in the air box? Lid is on secure? Carb is sealed to the intake?
martynkim wrote:Crack in the air box? Lid is on secure? Carb is sealed to the intake?
i have the lid rubber banded down with big bands because one of the clips on the lid is broken it is firmly attached to the carb
- martynkim
abreen89 wrote:martynkim wrote:Crack in the air box? Lid is on secure? Carb is sealed to the intake?
You might want to bag those rubber bands for some cable ties.
You could be sucking air there do what you can to seal it.
martynkim wrote:abreen89 wrote:martynkim wrote:Crack in the air box? Lid is on secure? Carb is sealed to the intake?
K sounds good marty im going to harbour freight tomorow ill pick up some cable ties
