Page 5 of 22
Re: Spree Engine Swap: Honda Elite CH80 onto Spree
Posted: Wed Apr 17, 2013 4:12 pm
by Tyler VR
patthesoundguy wrote:Dude that thing is so rad
I bet it wants to wheelie
If I would have kept the stock spree forks wheelies could happen easier. But I'm not into stunts...
Posted: Wed Apr 17, 2013 5:36 pm
by Tyler VR
Posted: Sat Apr 20, 2013 9:26 pm
by Tyler VR
Wiring almost finished, all the lights work. I need to get some plastics installed so I can go for a longer test run.
Posted: Fri Apr 26, 2013 4:29 pm
by Tyler VR
I put some plastics on and have been on a few test rides. I'm getting up to 45mph on flats and even more on a downhill. Acceleration is nice and hills are no problem, seems pretty healthy but I should do some maintenance/tune up and clean the carb.
I still need to fit a front fender and the side plastics will have to wait until I change the air filter and exhaust. Planning on ordering those now...
Posted: Fri Apr 26, 2013 5:46 pm
by Kevinstonge
Looking good. Tune the variator, and install a uni style oem filter and I bet you'll see 50 easy.
Btw, where did u go to purchase the threaded pipe/eye hooks for your frame support? Hardware store?
Posted: Sat Apr 27, 2013 3:56 pm
by Tyler VR
Kevinstonge wrote:Looking good. Tune the variator, and install a uni style oem filter and I bet you'll see 50 easy.
I'm planning on some variator rollers and a new drive belt on my next order of parts.
I got the joint ends for the frame support bar from a hardware store. I'm not sure what the proper name for them is, heim joint, fisheye joint, link joint, rod end, bearing end joint.
Posted: Sun Apr 28, 2013 11:32 am
by Kevinstonge
Awesome, thanks! And the pipe you just tapped on both ends?
Posted: Thu May 02, 2013 3:53 pm
by Tyler VR
Kevinstonge wrote:Awesome, thanks! And the pipe you just tapped on both ends?
Yes, I drilled the pipe on a lathe.
Posted: Thu May 02, 2013 3:57 pm
by Tyler VR
I just got the exhaust pipe I'm going to use, hope it will be good for the ch80. I should have time this weekend to install.
Posted: Fri May 03, 2013 1:22 pm
by Kevinstonge
Great, thanks. Definitely keep us updated on the muffler. I tried to find a suitable replacement over the stock muffler, but I gave up my search, and there's no way I'll spend what battlescooter wants for their's. Where did you pick up that muffler and how much?
Posted: Fri May 03, 2013 2:28 pm
by Tyler VR
Kevinstonge wrote:Great, thanks. Definitely keep us updated on the muffler. I tried to find a suitable replacement over the stock muffler, but I gave up my search, and there's no way I'll spend what battlescooter wants for their's. Where did you pick up that muffler and how much?
It's just a ebay pipe for $60 shipped. It has a 1in inlet connector, which is the smallest I could find.
Posted: Fri May 03, 2013 8:44 pm
by Tyler VR
I got the rest of my parts in the mail today.
Posted: Sun May 05, 2013 2:39 am
by Tyler VR
Getting started on the pipe install. I cut off the good stock pipe, which is a ch80 sin.
Posted: Sun May 05, 2013 2:47 am
by patthesoundguy
Its good to see your replacement for the stock can. Its only a sin if you diddnt have a good replacement but you do so its not a sin
Posted: Sun May 05, 2013 3:43 am
by Tyler VR
Installed, sounds pretty good.
