SE50 build
Re: winter build
Post by swimmingfree »
do you think it will work on my se50???
Re: winter build
the u.s. is going to he.ll. with the bull of being number one ..we ( the government ) think we no what best for other.. and all we do is Fire truck our self
Re: winter build
well i put the motor together all but a oil plug and put a spark plug in turn it over my hand and its got good compression ... boy is it looking good and cant whate till next year to get it on the road .. now i have 2 running motor one on the scooter not as fast as the new one but runs as a back up for now ... this coming spring ill do some heat cycles but in tell then ill be looking for use parts for a se50...
i wood like to thank all that have sold me parts an have gave me input :smile:
curtis966
Re: winter build
Post by curtis966 »
My malossi head on polini bbk on my af05e needed shroud modding to fit correctly.
paulpauly7
Re: winter build
Post by paulpauly7 »
mine didnt
Re: winter build
the head fit square to the jug on 3 sides an the side by the carb it hang over by about 0.25 inch.... the thing that is biggest is the after marked manifold that may make me mod the cooling cover a little.. but will have to whate to see if i need to do so..
thank for the input ...
Re: winter build
well got the short block together and boy its sexy ... by turning over the motor my hand its got good compression :smile:.. still need a fue thing too make it a turn key motor will be looking for them this winter...
patthesoundguy
Re: winter build
Post by patthesoundguy »
Can't wait for next spring when you bolt that bad boy in the frame :-)
Re: winter build
me as well :smile: how is the weather up north ???? here is cool 50 and going to rain if its not raining is picking up the leave and trying to get set for the snow...but is Michigan :smile:
swinningfree
Re: winter build
here a photo of the sweet little girl... if you dont see it its becase i dont have it...lol
Re: winter build
i no its been less then 24 hours cents my last post ... but have been thinking!!! was wondering if some one has ever tacking a v8 or other pipe and cut it up and welded ti back together to fit a se50 ???? i like the look of a Arrow pipe if what i have read is wright the longer pipe the lower the power band is... (i think tell me if im wrong ) i no that some pipe are made for different cc motors i have a 65cc bbk in case you don't no....
pleas feel free to tell me what you guys think ????
thank for your time ....
Re: winter build
dose inn body no if a spree and a se50 REAR SHOCK are the same ???? is one longer then the other??? or is the se50 just stronger then the spree ???and what about the dio REAR SHOCK???
thank for your time...
cruzingratiot
Re: winter build
Post by cruzingratiot »
maybe this will help stock elite shock 1994-01 next to aftermarket
aftermarket is set at 10-5/8 long eye to eye in pic
the elite is app 10 inches long
upper hole of 1994-01 elite shock 10mm
bottom 8mm bolt
just to show what type of hole placement in elite shock
Donate Life
http://www.donatelife.net/
Thank You
Re: winter build
the medsa im on i have gain some 25 lb in the last fue mounts im over 225 now and my little spree will grunt haling my fatttass around... lol!!! so i think ill need a better shock ...
Dakine
Re: winter build
Post by Dakine »
oh i wasnt reffering to any picture lol. I just read that you where doing a build on a se50 motor. Im talking about the driveface the round plate with teeth that goes in front of the variator and belt/
