Hi Gearhart.I was looking at that. The front wheel is very close to the frame. I don't think it will fit?Gearhart wrote:Cleanest way to do it imo is to put it right behind the front wheel in that plastic.
54mm build/ nuts packed in box
Re: 54mm build/ nuts packed in box
- 20171022_180244.jpg (170.37 KiB) Viewed 20299 times
- 20171022_180308.jpg (173.99 KiB) Viewed 20299 times
Nice... I like the jb weld case bracing!
No bracing Ben. JB Weld is only on one half of the case to add thickness, meat ,for sealing.benji wrote:Nice... I like the jb weld case bracing!
The other gray stuff is Permatex grey RTV sealer.
Hi forum. My friends spree is running slow. Can't keep up with traffic. Let's see if we can fix that.
- 20171130_005922.jpg (186.25 KiB) Viewed 20202 times
- 20171130_005842.jpg (172.63 KiB) Viewed 20202 times
- 20171126_190537.jpg (156.89 KiB) Viewed 20225 times
- 20171130_013642.jpg (156.31 KiB) Viewed 20202 times
- 20171130_013612.jpg (187.63 KiB) Viewed 20202 times
- 20171130_013523.jpg (116.79 KiB) Viewed 20202 times
- 20171130_015346.jpg (129.56 KiB) Viewed 20202 times
- 20171130_035712.jpg (157.11 KiB) Viewed 20202 times
- 20171130_035747.jpg (185.08 KiB) Viewed 20202 times
- 20171130_040938.jpg (196.67 KiB) Viewed 20201 times
- 20171130_040531.jpg (184.96 KiB) Viewed 20201 times
- 20171130_040428.jpg (162.07 KiB) Viewed 20201 times
- 20171130_043414.jpg (165.41 KiB) Viewed 20201 times
- 20171130_041234.jpg (134.78 KiB) Viewed 20201 times
- 20171130_041116.jpg (166.25 KiB) Viewed 20201 times
Forum, we going to make it a 129cc
- 20171130_043845.jpg (193.99 KiB) Viewed 20201 times
- 20171130_043814.jpg (208.51 KiB) Viewed 20201 times
Have you seen these cranks, ped? https://honolulu.craigslist.org/oah/mpo ... 26044.html
Good to know. thank you. I do like the PG crank. They can take a beating.Meatball wrote:Have you seen these cranks, ped? https://honolulu.craigslist.org/oah/mpo ... 26044.html
WOW! Nice work Ped! God forbid you have any air leaks on that monster! Do you think the stroker pipe you have will work well? Props for your extra efforts on the build!!!
- Xxbeejay45xx
This is NUTS!! Very mean build Sir!!!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Thanks Bones. The Stroke of pipe that I have will not work. I have a different pipe for my friends setup. A large tiada pipe.bonesv wrote:WOW! Nice work Ped! God forbid you have any air leaks on that monster! Do you think the stroker pipe you have will work well? Props for your extra efforts on the build!!!
Thank you sirXxbeejay45xx wrote:This is NUTS!! Very mean build Sir!!!
