Videos of aero problem
spajohn
Post by spajohn »
snikro wrote:Would running a few capfuls of seafoam in the gas help to do things like clear out the fuel lines and stuff on that end? I've heard it works wonders.
I've never tried seafoam, only heard of it. It's easier than taking the carb apart (which isn't that hard). You might give it a try.
snikro
Post by snikro »
I just wanted to know if something like that (meant to break down gunk) might be too hard on stuff like the fuel lines, which look to me like they're made of some kind of rubber. It's probably ok though.
spajohn
Post by spajohn »
snikro wrote:I just wanted to know if something like that (meant to break down gunk) might be too hard on stuff like the fuel lines, which look to me like they're made of some kind of rubber. It's probably ok though.
If it's meant to be a fuel additive, I'd imagine that it's ok for the fuel lines. It's a simple fix if it works. Give it a try, then clean out your carb if you still have a problem.
Post by Kenny_McCormic »
Well just pull the plug and have a look, also it could be ignition dunno how you could test it though.
snikro
Post by snikro »
Kenny_McCormic wrote:Well just pull the plug and have a look, also it could be ignition dunno how you could test it though.
I had the plug out a couple days ago and it's still that cocoa-brown color like in the other thread. I'm gonna try the seafoam though. Just a few capfuls to like 1/4 tank of gas is enough right?
