Page 5 of 9
Re: Turbo
Posted: Tue Sep 14, 2010 9:55 am
by fastplastic
air compressors make psi with electric motors only because they have a cyclinder or cyclinder like componets that are being moved by that electric motor simple as that if you think a hair dryer can make psi with out killing the motor your dumb ITS JUST A FAN BLOWING AIR NOT FORCING IT thats the difference there
Re: Turbo
Posted: Tue Sep 14, 2010 2:37 pm
by fastplastic
:lock: please lock this thread i dont belive there is hope for any kind of understanding :lock:
Re: Turbo
Posted: Tue Sep 14, 2010 3:36 pm
fastplastic wrote::lock: please lock this thread i dont belive there is hope for any kind of understanding :lock:
Who appointed you the thread locking decider?
Re: Turbo
Posted: Tue Sep 14, 2010 3:55 pm
by fastplastic
come on bear you have delt with these type of people, im trying to keep away from a fist fight or at least an internet one...
Re: Turbo
Posted: Tue Sep 14, 2010 4:10 pm
Who really cares and in the long run what difference will it make in the long run?
Re: Turbo
Posted: Tue Sep 14, 2010 5:26 pm
by nickisaninja
fastplastic wrote:air compressors make psi with electric motors only because they have a cyclinder or cyclinder like componets that are being moved by that electric motor simple as that if you think a hair dryer can make psi with out killing the motor your dumb ITS JUST A FAN BLOWING AIR NOT FORCING IT thats the difference there
Quit dreaming of 150psi of boost because these motors couldn't handle it anyway.
Yes, an electric motor could churn a couplepsi at 20cfm. Its not that hard. Fine, ill make my own thread and do it after my spree gets finished
Ok? Ill do it. Now shut up, quit shooting down bench racing. If you have any advice for me id like some help on what I can to do to increase volumetric efficiency.
Re: Turbo
Posted: Tue Sep 14, 2010 5:36 pm
by fastplastic
good luck i guess :jack:
Re: Turbo
Posted: Tue Sep 14, 2010 5:41 pm
by nickisaninja
Thank you.
Where can I find info on the stator total output? I'm thinking even a centrifugal turbo by brushless dc motor. I have a couple spare from r/c truck days.
I could even use a 12v battery on a big cap to take load off the stator. It looks small.
Re: Turbo
Posted: Tue Sep 14, 2010 5:57 pm
It is small. These scooter's alternators only make from 85 to 100 watts output, which is 7.08 to 8.3 amps and you do not have access to all the power either, there are lights to be run plus charging the battery. So it better be a super effeicent DC motor.
Re: Turbo
Posted: Tue Sep 14, 2010 6:17 pm
by nickisaninja
Good thing my spree's battery it twice the size of a normal one. Ill be putting the headlight on a switch and led the rear.
An auxilary pack would be awesome and have a switch to kill and charge off the battery when needed. Controllers and limiters would be weird but I have a charger that runs off a car battery...and is small enough to fit in my storage box with a battery and accessories.
I've got everything but the blower. Unless I don't know about it yet.
My moto is "make it work."
Re: Turbo
Posted: Tue Sep 14, 2010 6:35 pm
nickisaninja wrote:Good thing my spree's battery it twice the size of a normal one. Ill be putting the headlight on a switch and led the rear.
The headlight is on a separate part of the alternator that does not go thru the rectifier so all the switch will do is lower the load on the motor. The headlight is run off the direct AC from that section of the alternator. Maybe you could add a second regulator/rectifier and use that extra power. However just tying it into the present system will not work as the two charging systems will fight each other. That's why battery isolators were invented.
Re: Turbo
Posted: Tue Sep 14, 2010 6:59 pm
by nickisaninja
a bridge and regulator and cap to smooth phases would be easy.
Time to scavenge leftover pc power supplies and alternators from my volvo
Yes I am crazy.
Re: Turbo
Posted: Tue Sep 14, 2010 11:39 pm
by PimpinSpree
nickisaninja wrote:a bridge and regulator and cap to smooth phases would be easy.
Yes I am crazy.
your idea is not going to make any power. Youd be better off pointing your hair dryer backwards for a jet booster effect
Re: Turbo
Posted: Wed Sep 15, 2010 12:12 am
by nickisaninja
Yes I am crazy.
I'm not using a hair dryer it was an example of things that move air and everyone knows what it is.
I'm sorry you're offended that you didn't think of this first.
http://www.amazon.com/Flange-Mount-Blow ... B001449SYU
I'll bet you're going to try and tell me THAT isn't going to make a spree faster? Are you kidding me? Cramming a bunch of air isn't going to do anything?
I don't care what pressure it's going to be at, anything better than baro is going to improve power, that's not really an issue at the moment so drop the arguments.
Re: Turbo
Posted: Wed Sep 15, 2010 12:29 am
by nickisaninja
