Just got a Spree for 5$, need help
tommy9345
Re: Just got a Spree for 5$, need help
Post by tommy9345 »
toad772 wrote:
tommy9345 wrote:So what would be the method for testing the starter, I did find it and I have it disconnected, I have something that looks like a little plug with 2 prongs on it connected to the starter, what would I connect to it to test it.
Look at the picture that wheel man posted if you look long enough I am sure you can figure it out.
But first like bear said get a known GOOD 12v Battery and a good fuse.
Alright, I get it now. Also, I just opened the battery out of curiousity and all the caps are completely empty. maybe this is why the battery isnt charging? Im getting more acid later and then charging it. Hope it works
And the fuse that was blown before was a buss sfe 9. I got a buss sfe 9a to replace it, this is the correct fuse for a spree right? Its defninitely a 1985 btw.
A 1985 Spree actually uses a 7 amp fuse.
tommy9345
Post by tommy9345 »
Oh ok.. great.. haha when I get home Ill get a 7 fuse, would this be the cause of the problems ive been having?
tommy9345 wrote:Oh ok.. great.. haha when I get home Ill get a 7 fuse, would this be the cause of the problems ive been having?
The battery or the fuse? The battery most definately. As long as the fuse is not blown, No. But it wouldn't matter if the fuse was blown, the battery is trashed.
tommy9345
Post by tommy9345 »
So a different amp fuse wouldnt affect the starting? and it still wouldnt start even when jumping from a car battery, I think the problems deeper in the electrical system. Ill look at it more tomorrow. Could the CDI be blown?
toad772
Post by toad772 »
tommy9345 wrote:So a different amp fuse wouldnt affect the starting? and it still wouldnt start even when jumping from a car battery, I think the problems deeper in the electrical system. Ill look at it more tomorrow. Could the CDI be blown?
Even with a bad CDI the electrical would still work.
PS3 it only does everything.
tommy9345
Post by tommy9345 »
Then what could be the problem? Im lost.
tommy9345 wrote:Then what could be the problem? Im lost.
First thing that comes to mind is a bad fuse holder. Do you have power at both ends of the fuse and on the wire after the fuse holder? The only other thing that will cause no power to everything is a broken wire between the fuse and the first slice in the wiring harness. Of course the ignition switch could be bad. The ignition switch on my Spree, after sitting all winter always takes a bunch of on and offs to get it to finally work properly.
tommy9345
Post by tommy9345 »
How would I know if theres power at both ends? the fuse fits pretty snugly in the 2 holders and I didnt see any breaks in wires, but I havent checked thoroughly yet. Heres a picture of the fuse in the holder(it was the old 9Amp fuse that was in there before I changed it)
evilone
Post by evilone »
Test light? There are cheapo test lights out there that will do the job.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
kpa2004 wrote:Hopeless?
Back on page 4 I would have said no.
but here we are on page 6, no closer to a running spree. :cry:
tommy9345
Post by tommy9345 »
Ill do anything to get this thing running, my patience is unlimited :nerd:
I will spend months on this thing if I have to, theres only so much that can be wrong with it.
If you knew me, youd know I'm as stubborn as a donkey when it comes to making things that don't work, work :thumbwink:
Could I get a testlight at walmart or autozone? And how much would it put me back?
EDIT: And Id like to thank all of you so much for the help, I'd be completely lost without you guys.
odinxxix
Post by odinxxix »
yes you can get them at wal mart for around 5 -6 bucks.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
tommy9345
Post by tommy9345 »
Sweet, thatll be my next purchase towards fixing this d*** thing :evil:
tommy9345
Post by tommy9345 »
Btw, which places should I apply the tester Im getting tomorow? The battery terminals and where else?
