Twin dio possible?
Re: Twin dio possible?
Speed
A great opportunity for an lc twin 2t dio.Red Eft Performance wrote:What are your plans for cooling?
Twin dio possible?
By lc im assuming, liquid cooled? If so, It's been done before. You might consult DioSpeedDemon from YouTube. I know he has posted a lot vids on his bike and I believe it's lc. He put the radiator under the front panel an cut out a rectangular hole and replaced it with a metal grate I believe.eliteguy50 wrote:A great opportunity for an lc twin 2t dio.Red Eft Performance wrote:What are your plans for cooling?
1987 Spree
1994 Elite SR
1994 Elite SR
Liquid cooled is common, but a 2c2tlc has not been touched.
Last time i saw a water bore, it was beyond my budget. Do they have ones that are under $300?
Digging this sucker out of the bin.
I spent a few nights knocking out a desing in Autocad Inventor and I think that I ahve all of the design kinks worked out... Prototype time!
I have an engine half on our CNC mill and I have pulled all of the bolt holes locations as well as the crank center and the dowel centers out to half-thou from each other. Next plan is to carve this thing out of machinst foam and determine if I can put something together.
I don't have much in the way of pictures, but I will post them up when they come.
in taiwan , has done build 2 cylinder dio motor.. not new...
Im not doing this to be unique. I am atempting this for the * of it. I am also doing this on a cnc so that it can be rapidly replicated for others in the
I have an idea of changing the position of the intakes onto the front side of the motor. The theory is that it will pull a/f directly into the crank and will allow for a more compact design.
Nice, mate the intakes to the center section. How do you plan on connecting the cranks together? A coupler of some sort Id assume. I use to have a RZ500 LC, here in the states known as a RD500 LC and the cranks were 2 separate parts, its was a V4 design with upper and lower sets of reeds and 4 upper and lower carbs. Really neat bike I had bought brand new and kept through my 20s. Scary fast for "only" a 500cc.
A little photoporn
Inital idea inspired by input from those that have forgotten more than I know...
Measuring for the critical areas and cutting some foam.
I have the location of all the mounting holes sorted. It all lines up like it should. I need to go through and sort out the way that it is machined out. I plan on splitting the inserted case in half and bolting it together in a four-piece sandwich. I will transfer this all back into autocad and work out the details as well as a machining mount.
Enjoy.
Enjoy.
hehe well when you are ready i got some 49mm nicalsil bores for that !|
once get that tested , i want to try some 52.6 cranks 54 bores!
Well it appears that grainger has 175mm long M6 double ended studs for (reasonably) cheap. I think that I may machine this whole thing as one piece. Wonder what a chunk of billet will cost!
- tazland001
wow that looks kewl. I understand what you are doing but could never do anything like that. What a neat tool you got there. I got a wrench. lol.
No but really hats off. Cant wait to see more. The question is whos gonna ride that thing pegged.
Taz
Taz
Alright, me and Mr. Graham bell sat down for a little brain-fart session and after banging my head against the wall for a few hours, this is what fell out.
Basically I will shave 8mm off of each case and then machine this SoB out of some 6061 and build me a motor. As you can see, the intake ports are on the front of the motor and feed directly into the crank... I sized the opening to be 10% of a 28mm carb opening. I think that is correct, but I need some input!
Input required!!!!
Progress will come as follows...
Stage one: Design
I will complete the design now and determine if this is suitable for building
Stage two: Tooling
I will collect the correct tooling and build this part out of foam as shown in the previous posts. This will allow me to work the kinks out.
Stage three: Save my pennies
You think that building a AF is expensive, try doing two, and add the cost of a chunk of AL.
Stage four: Magic
That's right, I cut it.
Stage five: Grow bigger balls
Input required!!!!
Stage one: Design
Stage two: Tooling
Stage four: Magic
