Deuces 450.00 Dolla halla Build 2000 Elite SR
Red Eft Performance
Re: Deuces 450.00 Dolla halla Build 2000 Elite SR
Post by Red Eft Performance »
deuce217 wrote:Dang I have 3 sets of 9-1's
I run 9.1s on many bikes. They are good up to about 60mph. They will go 63-65mph with a high revving setup. Its all in what kind of riding you are going to do.
If you want to cruise at 55mph then the 9.1s probably are too short.
But If you want to rip around town blasting wheelies and occasionally hitting 60mph then I would say run the 9.1
Keith
Red Eft Performance
View products click => Here
deuce217
Post by deuce217 »
Keith
Thanks, maybe I should try some 7.97 or 8.4's per wheelman's suggestion. But I will try a set of 9-1's to see how they feel first. Maybe the acceleration will be worth the few mph up top.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
LMH
Post by LMH »
8.44s are the best of both worlds, you can still blast up to 70 if you want and a lot more low end power. 8.44s are my favorite ratio.
deuce217
Post by deuce217 »
Ha, that figures that I would buy 3 of the 9-1's then... Thanks Lovemyhonda. I will learn one of these days.
50mm BBK (tai)
V-8 pipe
dem0nk1d
Post by dem0nk1d »
deuce217 wrote:Image Finally got my continental ZIppy 90 90 10 tire in. Now I am tubeless, and clueless.
Are you running the front Met rim as well? Is that what i'm seeing here? I'm currently building an elite now, and sourcing front and rear met wheels.
"Like I tell people all the time Speed cost money ..if you have to ask how much then most times your not going to do it !" -tru72
--\\\Projects\\--
95 Elite Restore Project for Wife
1982 Honda Passport
2013 Honda PCX 150
