My 85' spree does run.. but needs some work...
Re: My 85' spree does run.. but needs some work...
okay guys i have my aire filter lid firmly on (tighter then stock) and i intalled a new hose clamp to the airfilter to carb connection. I also heli-coiled on the carb because they were in bad shape. So i fired her up and she turned over and idled AWESOMELY. took her for a ride i was reaching 27 mph at WOT which was faster then before, but after about a mile of WOT....................... glub glub glub and died. its was like i ran out of gas.. and she wouldnt turn over so i sprayed some mix into the air filter she started up just like before and ran good after a mile (give or take) died again WTH is wrong?
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock In The Works
Soft seizing, do a compression check and a plug chop.abreen89 wrote:okay guys i have my aire filter lid firmly on (tighter then stock) and i intalled a new hose clamp to the airfilter to carb connection. I also heli-coiled on the carb because they were in bad shape. So i fired her up and she turned over and idled AWESOMELY. took her for a ride i was reaching 27 mph at WOT which was faster then before, but after about a mile of WOT....................... glub glub glub and died. its was like i ran out of gas.. and she wouldnt turn over so i sprayed some mix into the air filter she started up just like before and ran good after a mile (give or take) died again WTH is wrong?
compression 105 psi
plug no. 18 on wikispreedia guide (good)
- Plugchopku4.jpg (116.97 KiB) Viewed 4730 times
Bear45-70 wrote:Soft seizing, do a compression check and a plug chop.abreen89 wrote:okay guys i have my aire filter lid firmly on (tighter then stock) and i intalled a new hose clamp to the airfilter to carb connection. I also heli-coiled on the carb because they were in bad shape. So i fired her up and she turned over and idled AWESOMELY. took her for a ride i was reaching 27 mph at WOT which was faster then before, but after about a mile of WOT....................... glub glub glub and died. its was like i ran out of gas.. and she wouldnt turn over so i sprayed some mix into the air filter she started up just like before and ran good after a mile (give or take) died again WTH is wrong?
bear if its soft seizing do i need to upjet? also i measure the float and it is off... would that cause my problem... and i would fix it but plastic doesnt bent and stay so i need to get a hole no float if you think that could be the cause.
That is what the plug chop is for. To tell you how much to upjet.
alright ill kill it at WOT and pull the plu and post pics give me a sec
alright i did the plug chop again and now it looks like number 19
- 205px-PlugChopExamples.jpg (49.91 KiB) Viewed 4725 times
- martynkim
You need to upjet too much to start and move down so you stop soft seizing. Running it too rich won't hurt anything while tuning. You have a leak somewhere. Stock bore and stock box and jet should be fine. However you can compensate for your leak by up jetting. I would start at 80, then move down.
martynkim wrote:You need to upjet too much to start and move down so you stop soft seizing. Running it too rich won't hurt anything while tuning. You have a leak somewhere. Stock bore and stock box and jet should be fine. However you can compensate for your leak by up jetting. I would start at 80, then move down.
So should i just buy an 80 jet or should i buy a bunch of different ones?? wheres the best place to buy jets??
Free bump for abreen89 who is a good guy to do business with, I just got the emulsion tube from him at a decent price.
A true ScootBro!!!
now, let's get
Check on ebay, I saw some main jets for sale there:
http://www.ebay.com/itm/Honda-Spree-NQ5 ... 419&vxp=mt
http://www.ebay.com/itm/Honda-Spree-NQ5 ... 98&vxp=mtr
+He who dies with the most toys wins+
