you have to use extra 3M tape. to get them to stick on.
First spree AF16 motor swap. more photos of motor work.
Re: First spree AF16 motor swap
got some yellow LED driving lights
also put two at the back.
- 20131106_231837[1].jpg (199.06 KiB) Viewed 10875 times
- 20131107_032851[1].jpg (149 KiB) Viewed 10875 times
- 20131107_033017[1].jpg (166.64 KiB) Viewed 10875 times
some motor work photos.
photobucket s**ks how come the link is not working! awww.
anyone know of a good photo storage I can download photos? thanks.
hi graphite9. yes i'm new to photobucket. what's the link I should be using?
thanks. I hope everyone can follow the photos?
. this is the motor build. some photos are out of focus
hi forums, try and follow the photos, if you can.
To see how I put the motor together. I know it's fuzzy, sorry.
* camera.
It was my first build.
not sure how it was going to come out?. but runs good. waiting on pipe and carb.
motor has a new crank. bearings, seals, head, piston, gears, springs, veriator, not everythings on photos.
Re: First spree AF16 motor swap. more photos of motor work.
That boost port came out looking good. But did I read the pics correctly? Did you put the bearings on the frozen crank first??
Honda-san ordains that you tap them into the cases first, then pull the crank through. I hope you didn't reverse that.
hi wheelman. yes I did. then realized it was wrong. had to pull them out with a puller. heat the case, and install bearings. and pull the crank through.Wheelman-111 wrote:Greetings:
hi forum. well, I won't be going out to eat for a while. thanks to this addicting scooter habit. is it just me? or is there something about a scooter that puts a smile on your face
. looks like I am going to go broke with a smile
hi graphite. 15graphite9 wrote:You think you have a habit? I have 15 scoots in my shop. All my own. I'm seriously sick..
well I am glad I'm not the only one. who likes to tinker with scoots
- swimmingfree
ped
all of us that that help other out here go to a S.A. class its like A.A. or N.A. lol!!!
swimmingfree wrote:ped
that is funny swim. lol.Life's a trip enjoy the ride.
hi forum. I could not find the vw exhaust gasket for my PG short. but I did fine this walker gasket. number 31676. I don't know what it fits.
I had to make the hole like 2mm wider, dremel or file. it's a metal core, sandwich with gasket material outside.
I had to make the hole larger. gasket has a metal core inside. the price was $5. per gasket. walker part number 31676.
if your going with a bigger pipe it may not work for you. it looks good for the PG short. with a 29mm inside diameter. hope this helps if you can't find the other gasket.
- 20131219_183703[1].jpg (137.5 KiB) Viewed 11075 times
