Hi Beejay45. The scooter looks great. And the pipe looks sweet
Very creative with the bracket.
I was just curious if you made a complete U bracket, and attached it to these two bigger bolt holes. Do you think it would be stronger? or maybe all 3 bolt holes? Just curious if it would work?
Again nice looking scooter. I see a lot of work.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow red contra with yellow clutch springs. RIP CITY RIP NO MERCY KERSEY
ped wrote:Hi Beejay45. The scooter looks great. And the pipe looks sweet
Hello Ped sir, Thats a great idea also, but unfortunately I didn't have enough material to make it connect to the other hole. As of right now it's holding strong, more riding will tell how it all this holds up. Did 50mph easily without a hiccup. Really gotta tune the trans to make this all complete. Thanks for you advice.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
So i washed and waxed my scooter and took it out for a test tune..... So I come to find out the 2000 rpm contra spring are only good for short bursts upto 40-45ish and dies out. Tops out at 48mph with 9600 rpms 150 main jet. I swapped out 1000rpm contra spring and the main jet down to 146 and I get 54 mph with 9100 rpms and ran out of pavement. Still with 5.5 rollers. The stiffer contra spring don't let it switch gears even with heavier rollers. Here's some pictures, I think I almost got it dailed in.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Yes indeed sir I'm working my way down. Still lean on my main jet for sure. Polini carb is calling for
Me so that's the very next item I'm purchasing! Gotta believe I can fly!! Lolz
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
graphite9 wrote:Representing, my man! Love your bike its so clean and the rear disk is bada$$. I haven't ran a oko for a few years, but shouldn't you be around 125-138 on MJ?
G9 you are absolutely correct I need to be one more down to a 140 still see max temps @ 376 and 9200 rpms. I don't like these 7.2 gears anymore, Thanks for the input!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
