Page 6 of 11
Re: update
Posted: Mon Jun 30, 2008 11:05 am
by burnt_toast
I on the other hand don't see how you're running a 152main, crazy rich but location and elevation plays an important role, thats what guy in Alaska is running. I'm pretty close to sea level. I always keep an eye on temps and haven't had it ever go above 400F, usually 350-380F when wot for long distances.
happyman wrote:am amazed you can run such a small main jet. the 135 i think would be pretty lean. i run the 152 main with a 50 pilot needle has clip in the midddle and the plug looks good.i know we have to be real careful with heat. when it start pulling a little it make them head to the danger zone quickly. some times i wonder why it is moving close to the 400 mark too, the motors seem to require we pay attention all the time.
you do have a real great running scooter to get the top end up there. i can match that buit i need help from a little breeze behind me. usually a run in the mid to high 60's no wind is bout it for me on a GPS i run 6 g rollers also. which i think are smoked now
burnt_toast wrote:New tune today, 2K center spring, Stock Jog clutch grab springs,
37.2g in lightened Keli (up from 31.9g), pilot up to 50 from 48, main at 135
Fastest speed yet! Down same flat as last time, with front and rear tuck with knees close in..
73.8 MPH! by Garmin GPS of course
I was very suprised to see the new higher speed even with the 2k center, but the extra weight in vari pushed it.
Launch still needs work, but better; and once warmed up theres a flat spot again in between 25-35mph ugh!,
but hey cant have it all right heh
Re: update
Posted: Mon Jun 30, 2008 3:49 pm
by happyman
i had an idea you were gonna make that statement.. i am at 570' above sea level. so in reality it should close to what you run. you have i would guess higher temps than we have here. like today its about 83 and 40% humidity.. the air is pretty fresh. but like you say, that is a big jump from what your running. i have seen wher eothers are tunning pretty much what i am running for jetting.. the dude from alaska for one as you stated. my plug looks to be right where it need to be. could maybe go one step down. makes me wonder if i have s leak somewhere at times. i can if not buckig a strong wind run wot for miles and miles have done it cojuple times for 20 mile shots anywhere from 9500-9960 RPM. thats a plus 70 mph at all times. runs cooler that way than at 45 mph. going against the wind it pulls it hard and its then i see temps go up faster than i like.. maybe i need to look things over a little hate so puke this build. any ideas are welcome
burnt_toast wrote:I on the other hand don't see.. how you're running a 152main, crazy rich but location and elevation plays an important role, thats what guy in Alaska is running. I'm pretty close to sea level. I always keep an eye on temps and haven't had it ever go above 400F, usually 350-380F when wot for long distances.
Posted: Fri Jul 04, 2008 10:14 pm
by burnt_toast
Posted: Fri Jul 04, 2008 10:17 pm
by Dac
Nice.
not sure if its something i would do, but i like it.
totally custom.
Posted: Fri Jul 04, 2008 11:30 pm
by Kenny_McCormic
Thats neat, just cap it off when riding, dirt in oil=bad.
Posted: Fri Jul 04, 2008 11:33 pm
by happyman
thats a pretty good idea. makes travel a little easier if yu can keep gas stations at 40 miles or less.
Posted: Sat Jul 05, 2008 12:14 am
by burnt_toast
Kenny_McCormic wrote:Thats neat, just cap it off when riding, dirt in oil=bad.
True I thought about that, I'll see how it is when riding. Cool thing is since its just the unmixed oil, most dirt should still get trapped after premix were I have a two stage fuel filter setup.
Posted: Sat Jul 05, 2008 1:05 am
by Dac
eh, no since in getting your filters all dirty, cut find a small cap for that. see if you can find like a marker cap that would fit.
Posted: Sat Jul 05, 2008 8:59 am
by burnt_toast
Dac wrote:eh, no since in getting your filters all dirty, cut find a small cap for that. see if you can find like a marker cap that would fit.
I will when I start riding, mostly on the Jog now goin slow pace =RESPECTA@!
Posted: Fri Aug 08, 2008 11:39 am
by burnt_toast
On Wed, July 23 2008, this happened:
http://www.hondaspree.net/phpBB2/viewtopic.php?t=6359
I was being pretty stupid and ran the Elite for about 10mi on highway at WOT nearly the whole way, hella fun but hella stupid, as a "low" oil ratio of 40:1 bit me in the *..
In my quest for a new cyl kit I had my mechanic at the shop take a look at my Corsa piston and cyl and say its repairable! So I decided why not?! And within the span of a week cleaned up the cyl, piston, and rings, re-used what I could and cut out some pretty new base gaskets. THIS time I use only TWO for a much better squish band and higher compression.
Results are Elite is alive yet again, until something I re-used decides to go hah..
Right now I'm maxed out w/ jetting and may need to up it even more:
At about 75cc, actually using the ministroke this time
In 28mm OKO 145main, 58pilot! 37g in Keli Vari
Update pics, while she was down added new rear brake pads, new Michelin S1 3.50 rear tire, NGK plug boot, removed nasty fuel strainer only inline filter now, and painted the PG BBQ Flat black
Posted: Fri Aug 08, 2008 11:58 am
by Kenny_McCormic
The flat black makes it less noticeable, more sleeper like.
Posted: Fri Aug 08, 2008 12:37 pm
by happyman
really a nice looking scooter you have. you had the same thing happen to you as i did but now i run 20 miles plus twisrted as far as it can go and done it a couple times my fuel is a bit differant than yours but its keeping it cool enough to maintain a safe temp.. still running the 52 pilot and 150 main, feel i could come down on the pilot but when the weather cools it will be no problem. the plug looks like a plug should on a 2t. i run 50:1 mix but i use the amsoil sabre professional. it seems to work very well. on the other elite that is setup as injector with 24mm carb i use the Dominator oil and its good stuff also , been using it my kymko for a couple yres and its kept the cylinder looking good and i spool it hard compared to who i run the elites.. it spools 11500 rpm so that is putting it to the test.. what is the oil you run? anyway you have a neat scoot. mine are the purple color but its ok i guess..
burnt_toast wrote:On Wed, July 23 2008, this happened:
Posted: Fri Aug 08, 2008 1:36 pm
by burnt_toast
Kenny_McCormic wrote:The flat black makes it less noticeable, more sleeper like.
Sleeper is my middle name
I'm glad it turned out that way actually, stock looking unless you roll by me hah
Thanks for the comments guys
Castrol 2t is my oil.. basic and cheap. Will be looking for better local alternatives shortly
Posted: Fri Aug 08, 2008 2:24 pm
by happyman
glad its running great . hey becareful of the tiresw on there it appears in pic to be very very close remember when your going 70+ MPH the tires reallt grow in height and get skinny. just a little heads up is all. it could get real ugly if they start really hitting something at that speed
burnt_toast wrote:Kenny_McCormic wrote:The flat black makes it less noticeable, more sleeper like.
Posted: Fri Aug 08, 2008 8:48 pm
by burnt_toast
happyman wrote:glad its running great . hey becareful of the tiresw on there it appears in pic to be very very close remember when your going 70+ MPH the tires reallt grow in height and get skinny. just a little heads up is all. it could get real ugly if they start really hitting something at that speed
Yeah I know, something I thought about but hope for the best..
