****Official Picture Post****
Locked
evilone
Re: ****Official Picture Post****
Post by evilone »
808BMW wrote:And now back to the moped pictures...
Great idea, i click on the link to see pics. I'd drive that VW any day, below is my "dream" car.
Is that pipe louder with that leak?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Post by eliteguy50 »
Is that a broken PG Long?
odinxxix
Post by odinxxix »
evilone, man what a dream car, but alas i believe they only made like 500 of them and i only know 2 in existance. i myself would like to have a 69 camaro rs\ss.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
zuphilius
Post by zuphilius »
odinxxix wrote: i myself would like to have a 69 camaro rs\ss.
Back in '76 I almost got one of those for $1200. I got a '68 Charger instead.
I did not know The Judge was that rare. The guy who owns the shop two blocks down has one that he did a full frame off restoration to a few years back.
odinxxix
Post by odinxxix »
ok let me clairify in the particular paint scheme. not the judge itself.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Ohh, that makes more sense. His is the orange base coat.
808BMW
Post by 808BMW »
evilone wrote: Is that pipe louder with that leak?
Insanely loud. I rode it like that all the way home, my ears were ringing for 45 minutes after I got off the bike :P
eliteguy50 wrote:Is that a broken PG Long?
No it's my expansion chamber from jiangwayne:
It had a small crack (improper installation, I was missing the thick exhaust gasket needed for this exhaust) and I did a REALLY tall stoppie. When the back slammed down, the small crack turned into a gaping hole :P
shakenbake
Post by shakenbake »
Just for fun...I will post up my other Honda!!!! The spree's are next!!
88 Honda Civic RT4wd 360whp
The build thread link-
http://www.hondacivicwagon.com/bb/view ... =5&t=10570
Engine/Drivetrain
-D16z6 block & head
-VIPwryann ported Z6 head
-GSR throttle body
-crower valve springs & retainers
-stock z6 cam & cam gear
-Wisco pistons
-Eagle H beam rods
-Block guard
-ARP head studs
-Clutch masters stage 6 six puck flywheel
-3ÔÇØ strait stainless piping, two glass packs
-custom built VIPwryann turbo manifold
-Tial 38mm wastegate
-GT3076r turbo
-3ÔÇØ down pipe
-1600cc injectors
-GM 3bar map sensor
-VIP tuned Crome Gold P28 ECU
-custom built OBD0-OBD1 jumper harness
-CX racing radiator
-Samco upper and lower radiator hoses
-Godspeed intercooler
-HKS SSQV BOV
-VIP custom built 2.5in charge pipes
Exterior/Sup.
-Sportmax 0 offset 15X8in wheels
-DA lip
-Koni yellow struts
-Ground Control coilovers
-Avid Racing traction bar with custom built front engine mount bracket
-OEM Honda wagon window visors (not installed yet)
-VIPwryann rear diff bushing thud modd
-yellow high beam bulbs
-6000k
Interior-
-NRG 2.0 quick release
-NRG EF/DA short hub-
-NRG steering wheel
-OEM Honda Red ÔÇ£HÔÇØ horn button
-LED dome lights
PicÔÇÖs
Are you aware that the first US Honda cars had motorcycle engines in them? Then they screwed up and made their cars with car engines.
Bear45-70 wrote:Are you aware that the first US Honda cars had motorcycle engines in them? Then they screwed up and made their cars with car engines.
Are you sure Honda didn't just start putting car engines in their motorcycles instead? Try riding a modern goldwing. :crazy:
The Goldwing wasn't even a twinkle in Honda's eye back in 1697 when the N360 appeared and 1969 for the N600 coming on the scene.
Spreetard
Post by Spreetard »
Honda builds engines. The cars and bikes that surround them are a mere side effect. I can personally tell you that a d16a is a bulletproof powerplant that will run all day, every day in the 6k+ range. B series are also amazing engines. Same with the K's.
:love: I love Honda! :love:
Not all the vehicles they build are the best, but the engines are world-class.
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
808BMW
Post by 808BMW »
That is exactly the type of honda I would build, if I were to ever own one. Built Sohc-V with a REAL turbo setup, and good tuning, even the GC's and low offset wheels. That's exactly what I'm building, except it's an 89 BMW instead of an EF honda :P
Now bust out some pics of that spree? ;)
So I finally got to cruise around on my day off, my buddy has a fresh bike built for fun. Good times.
fastplastic
Post by fastplastic »
Spreetard wrote:Honda builds engines. The cars and bikes that surround them are a mere side effect. I can personally tell you that a d16a is a bulletproof powerplant that will run all day, every day in the 6k+ range. B series are also amazing engines. Same with the K's.
:jack:
Locked
