MONSTER Spree
Re: MONSTER Spree
At that price you can get the whole intake and reeds. besides those are for the Yamaha Blaster quad.
- SpreeMadness520
Re: MONSTER Spree
the intake I have fits the same reeds as a yamaha blaster, V force are far better then the ones it came with. Just making sure those are the right reeds.
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
Re: MONSTER Spree
For a $123 dollars they better double the horsepower or they are not worth it. If they give you 1 or 2 mph I would be surprised.
Re: MONSTER Spree
yeah thats the one. dont run the insert that they send with it since your using it for dragracing.SpreeMadness520 wrote:the intake I have fits the same reeds as a yamaha blaster, V force are far better then the ones it came with. Just making sure those are the right reeds.
Re: MONSTER Spree
believe it or not it increases hp and torque with the 4 reed design.yeah it has 4 reeds on that cage. moto tassianari makes one for stage6 which holds the 1/8mile record on a 70cc setup which is under 8sec.Bear45-70 wrote:For a $123 dollars they better double the horsepower or they are not worth it. If they give you 1 or 2 mph I would be surprised.
- SpreeMadness520
Re: MONSTER Spree
- engine.jpg (148.72 KiB) Viewed 6936 times
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
Re: MONSTER Spree
Hey just to let you know,on the block on the right side of where you mount the manifold. You have to fill in the cutout with either jb weld or aluminum. The manifold hangs over the cutout so it will leak there. Unbolt the mani and you will see the imprint on the gasket.
- SpreeMadness520
Re: MONSTER Spree
Are you just using the base gasket that came with the mani?SpreeMadness520 wrote:Already did bakaIm on top of my s***
- SpreeMadness520
- Trafficjamz
Re: MONSTER Spree
bakaracer wrote: believe it or not it increases hp and torque with the 4 reed design.yeah it has 4 reeds on that cage. moto tassianari makes one for stage6 which holds the 1/8mile record on a 70cc setup which is under 8sec.
What is the 1/8th mile record on a 70cc setup?
Re: MONSTER Spree
The ones that come with that mani are prone to leaking and sealing good. You need to either use copper rvt with it or buy the thick gasket paper so it squishes down to seal better. Unless you filled it in by welding aluminum then lathe it down to match the intake mount, its still uneven and that thin gasket will leak. So don't get to *!SpreeMadness520 wrote:No the intake came with a gasket
Re: MONSTER Spree
They dont race the 1/8 mileTrafficjamz wrote:bakaracer wrote: believe it or not it increases hp and torque with the 4 reed design.yeah it has 4 reeds on that cage. moto tassianari makes one for stage6 which holds the 1/8mile record on a 70cc setup which is under 8sec.
One of the fastest times I have heard is from my friend Marc Grauer who help start the maxiscoot magazine. In 2006 did 7.44@78.4 in 150 meters (164,05 yards) on a 70cc set up..
- 39068p1050230-med.jpeg (77.32 KiB) Viewed 6925 times
Re: MONSTER Spree
The 7.4 sec is for the 201m. The 150m is now 6.4sec. As for the 1/8th mile time it was something I read about that I remembered on one of the parts website selling the stage6 rt kit. But isn't the 201m considered 1/8th mile? That's a little over 600ft. I know they are doing 12sec 1/4mile times
Re: MONSTER Spree
220 yds in the 1/8th
