Page 7 of 12
Re: soft seize?
Posted: Sun Feb 26, 2012 11:56 am
by iceman77
my buddy has a press. he would do it for me. what's the benefit of porting it?
TJ
Re: soft seize?
Posted: Sun Feb 26, 2012 12:03 pm
by swimmingfree
more mix moving faster and ezer .. = more rpm and hp
dont remove the post
if you do it may case a air leek
By freeswimming at 2012-02-26
Re: soft seize?
Posted: Sun Feb 26, 2012 12:16 pm
by iceman77
awesome. thanks for the info.
TJ
Re: soft seize?
Posted: Sun Feb 26, 2012 12:31 pm
by paulpauly7
Pressing or pushing the cases together is not the way to put the crank back you risk damage to the crank it needs to be pulled into each case
Never use a mallot to install a crank
Re: soft seize?
Posted: Sun Feb 26, 2012 12:33 pm
by Mystic
While I dont recommend using a mallet pauly, it can be done especially with these small cranks. I have done it without any problems
Re: soft seize?
Posted: Sun Feb 26, 2012 12:59 pm
by swimmingfree
pm sent
take a ring put it in the jug on the top use the piston to puch it down about 1/2 in and use a filler gage to get it speck are in the book..
pm i got from iceman77
.013 is what i got.
Re: soft seize?
Posted: Sun Feb 26, 2012 4:24 pm
by iceman77
this is the best i could do. it was my first one so not bad i guess.
Re: soft seize?
Posted: Sun Feb 26, 2012 5:08 pm
by bakaracer
Mystic wrote:personally I wouldnt let lack of tools stop me you just have to use your head and take it easy. I used a rubber mallet and pieces of wood to put my cases back together :D or you could call around to some engine shops and see how much they would cahrge to press them back together once you enlarge the intake
NO!!!!! Horrible advice
Re: soft seize?
Posted: Sun Feb 26, 2012 5:10 pm
by bakaracer
swimmingfree wrote:i use the bolts to do it the long ones off the jug first and take it slow and keep it square and even..
And another NO!!
Re: soft seize?
Posted: Sun Feb 26, 2012 5:16 pm
by bakaracer
When installing the crank bawck into the case,it needs to be pulled into the crank bearing. Never use a hammer of any type and never bolt the case together to get the crank into the bearing. Using a hammer will damage the bearing from damaging the ball bearing and inner race. Trying to bolt the case together to try and get the crank into the bearing you risk stripping the bolt holes,crack the case and the crank doesn't seat all the way in the bearing. So guys those were horrible advise you gave and people don't follow those advise unless you want to either ruin a block or blow your s h I t up!
Re: soft seize?
Posted: Sun Feb 26, 2012 5:32 pm
by Mystic
While I value your opinion baka if you didnt notice I didnt recommend him doing it with a hammer just saying that I have :P I advised him to pay a shop to do it for him since he didnt have a crank tool
Re: soft seize?
Posted: Sun Feb 26, 2012 5:43 pm
by bakaracer
you never press the cases together. there are aot of shops out there that have never touched engines like these. if the customer say to press them together, thats exactly what they will do and use a press. if your going to give advise, please give the right one. there are alot of people that have no clue that come on here asking for advise and if they see that a member that has been on here alot or is on here often, most times they will take that advise so you need to be careful what you say.
Re: soft seize?
Posted: Sun Feb 26, 2012 6:14 pm
by kingkamehameha
Get a tusk crank puller its a good tool to have. Saves you a whole lot of headache.
Re: soft seize?
Posted: Sun Feb 26, 2012 10:17 pm
by iceman77
well i used my friend's press. baka, i had already put it back together b4 you left your advise of not pressing it together. It went back rather easy so i'm crossing my fingers that everything will be alright.
TJ
Re: soft seize?
Posted: Sun Feb 26, 2012 10:41 pm
by bonesv
kingkamehameha wrote:Get a tusk crank puller its a good tool to have. Saves you a whole lot of headache.
Must have tool, no question. I would never attempt to short cut this method.
Easy as pie!
Protecting the connecting rod from damage:
All finished and ready for cylinder. Just trimming the gasket a bit for full flow transfer ports:
A nice little trick for the oil pump plug:
A little hand polishing on the exhaust port and piston dome, as recommended by bakaracer:
