First spree AF16 motor swap. more photos of motor work.
deuce217
Re: First spree AF16 motor swap. more photos of motor work.
Post by deuce217 »
Great photos. Looks like a VW gasket. I have bought several to keep on hand. I was abe to get them for about .47 cents each through an auto parts store.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
ped
Post by ped »
thank you deuce. better photos of port.
ped
Post by ped »
the plug holder. I got the idea from the forum. thank you whom ever it was. Very nice people in this forum. :thumbwink:
Post by swimmingfree »
you may need some goo behind that quarter....
ped
Post by ped »
hi swim. there a oil plug behind the quarter. almost done with the carb & pipe install :happy:
ped
Post by ped »
ped wrote:the plug holder. I got the idea from the forum.
its tight I have blue Loctite on threads. :happy: maybe I will use a little. :nerd:
if air leeks by the quarter it will run lean and we all no what that means....
ped
Post by ped »
swimmingfree wrote:if air leeks by the quarter it will run lean and we all no what that means....
A hole on the piston? oh! your saying the o-ring is not enough. got it . thanks will do more sealing.
better to be sure that all is leak free...
ps
you have a good read and nice photo as welll :smile:
ped
Post by ped »
swimmingfree wrote:better to be sure that all is leak free...
ps
thank you again swimmingfree. just like this fourm helped me , maybe it will help someone else :coolcruise: .
ped
Post by ped »
graphite9 wrote:Ped, I have the correct carb cable for your oko. Your going to have issues with how you have it set up now. I doubt your slide will even close with that cable. It will probably start at 1/3-1/2 throttle
thanks graphite. I not finish with setup. did you noticed how close the pipe is to the fan shroud? looks like I will have to order some exhaust wrap for the pipe. :coolcruise:
ped
Post by ped »
my new premix oil baby bottle. holds 9 OZ. $1 at dollar store :smile:
refl3x
Post by refl3x »
did someone say scooters in civics?
is that throttle cable in the picture above off of the spree?
ped
Post by ped »
refl3x wrote:did someone say scooters in civics?
I see you need to take your scooter other places too :lol:
yes the cable is off the spreedio. just waiting on CHT gauge. to install together.
ped
Post by ped »
I did the pilot jet trick. some one on the forum showed how. I can't remember who. thanks for the tip. :thumbwink:
I cut away a little on the bowl. so the pilot jet will come out, without taking the bowl out.
:2thumbs: for the person who posted that trick. :smile:
Thanks for the tip cruzingratiot . you have a very nice detail build. :thumbwink:
I file down the screwdriver to fit in the small jet.
very little was cut out.
