Low miles 1985 Aero 50 restore
- swimmingfree
Re: Low miles 1985 Aero 50 restore
you may have put too munch oil in it ... that wood make it flood out...
- PorterGuy85
I just pulled the plug, disconnected the vacuum line on petcock & drained carb bowl. Spun it over a few times & let sit. Hopefully when I do get it running, this doesn't happen again. Bystarter not closing cause this? I tested it & the needle does protrude out. I'll check it to see if there is an o ring at the end & remove it.
- PorterGuy85
Self mixing, how would this be possible? Does oil come out even when just cranking it over? Gear being engaged on oil pump?swimmingfree wrote:you may have put too munch oil in it ... that wood make it flood out...
- PorterGuy85
Double checked to see if I have spark, nice strong blue sparks!! Put on the vacuum line, filled carb bowl & tried to go. Nope. If I listen closely i can hear a liquid in the crank. So looks like I'm diving deeper & taking more apart. I could tip the bike but have to remove oil & gas tanks. I'm almost there, again.
- PorterGuy85
- 2014-05-31 09-03-40-169-1.jpg (171.88 KiB) Viewed 10022 times
- 2014-05-31 09-03-53-833-1.jpg (223.18 KiB) Viewed 10022 times
- PorterGuy85
Has been sitting for a few days to dry out, going to tip it over to see if any residual oil drips out from jug. Then I'll put it back together & try to start it. Reeds looked good from the top. Couldnt really get it out to see the bottom/stoppers, should that be a definite thing to check?
- PorterGuy85
Power tower tipping
- Hopefully tipped enough
- 2014-06-05 09-07-58-413-1-1.jpg (229.95 KiB) Viewed 9989 times
- PorterGuy85
Reed looks good, flaps open & close good. Now I need a new gasket or make one.
- 2014-06-05 11-03-22-581-1.jpg (150.29 KiB) Viewed 9987 times
- 2014-06-05 11-03-05-212-1.jpg (111.16 KiB) Viewed 9987 times
- 2014-06-05 11-02-50-841-1.jpg (160.1 KiB) Viewed 9987 times
- swimmingfree
if you look do you see light coming around the reeds look on the side that gose to the carb ...
- PorterGuy85
Nope, no light. Maybe i'll get lucky & it will fire this weekend with all this taking apart & cleaning/inspecting.
- PorterGuy85
- swimmingfree
pull the plug if wet leve out the plug and roll the living out of the motor to dry it out...if dry put a fue drops ( 10 or so ) of gas in the hole and try it again... have you done a compression test on it???
- swimmingfree
try kicking it over ... do you have spark???
- PorterGuy85
Spark, yes. Psi, 118.
- PorterGuy85
So I need to recheck my compression test, why?
Because I might have a worn cylinder. Somebody else had same issue with starting. Everything else was fine but a slightly worn cylinder. It took a good number of starts to build up to that psi. It should get to at least 90psi in a second or two. Does this make sense? If so, might be my issue. I can get 118psi but takes a few more presses of start button than it probably should to build up my psi. I will redo it and see what psi I get to within the first burst of start button.
