The problem is you're reading head temp on a water cooled head. You read the water temp just like a car, not the head temp. You can read the head temp as well as long as you know what the baseline temp is. I should have added this when I read you were using the cht as your temp guide.
Plug chops also do wonders for 2t. Don't trust your gauges until you know for sure your engine is fine. Furthermore, use a water temp send unit next time and ditch the cht. To me a cht on a lc bike is absolutely a waste of time. Too much ambient temp spikes and lulls.
Whitey's stroker
1man8scoots
1man8scoots
Re: Whitey's stroker
Also sorry to hear! There may be replacement over sized pistons but your piston is pretty much max on size I'd guess.
I just got a trail tech temp sensor in the mail yesterday that goes inline on a hose. I'll put it on the coolant line coming out from the cylinder. I think I need a new batt also, it has power but my battery charger indicates that it's bad.
78 Honda Hobbit Athena
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
1man8scoots
I use to run one out of the radiator and one from the output of the cylinder. Now I only have one coming out of the cylinder 6 inches before the radiator. If you put it too close to the cylinder you may have ambient heat from the cylinder structure adding to the temp. Use your best judgment.
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
1man8scoots
Jb weld it back together.
That's a bummer man. How did your plugs look before?
- Rip_City_Spree
Yikes
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
