Flash 9: Sanity Restored
Re: Flash 9: Sanity Restored
Wheelman-111 wrote:Greetings:
I have a bucket of Gin-You-Whine Harley-Davidson Screamin' Eagle needle shim washers for the uh, Ahem... Japanese carbs used on the mighty V-Twins. Somewhere...
Glad to see youre doing OK, Wheel...all the destruction on the news had me worried. You must be deep enough in-the-harta to dodge Harvey.
Actually Wheel-house lies in the coastal town where Harvey made landfall. Category 4 North wind and sheets of rain Pummeled for 3 hours before Ms. Wheel-person and I took a stroll in the Eye. Gentle breezes, moon in the clouds around 23:30 or so, for 25 minutes before east eyewash Southerlies repeated the beatings from the opposite direction, albeit a bit less intense.
Our house took it like a champ; rain gutters, mostly. Abundant live oaks softened the blows as they gave their lives, uprooted. Others were not so fortunate; many lost all. Communication was down for 2.5 days and we were land-locked, but alive. Water returned for 8 hours yesterday, power maybe in 1-2 weeks. Have grill, campstove, generator for fridge and fans, and jungle scooter rides to enjoy.
Rip_City_Spree
Post by Rip_City_Spree »
d*** glad you and yours are safe.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
ped
Post by ped »
Wheelman is this you? https://www.youtube.com/watch?v=sueMfSgTm4A :surprise:
On the serious side glad you ,and your family are safe.
Yes, Ped, that was Ms. Wheel-Person and I on F9,fitted with a snorkel for the air box. AF16 is now liquid-cooled!
ped
Post by ped »
Hi wheelman.
I understand that it's very hard for a lot of people in Texas right now. I'm also glad that you guys are getting help. Hope things get back to normal soon. Stay strong be safe.
Update as F9 frame now has over 5000 miles, though the 9th engine build probably only a fifth of that. Anyway, it had resumed dripping - just a drop every 2-3 days or so, with tell-tale red color indicating fuel (with pre-mixed Motul) was the problem. It had also become increasingly hard - like 22 kicks - to start after sitting for as little as 48 hours.
I bought a complete carb gasket kit along with a new air screw + the little washer/o-ring that sits astride that jet. Dipped the carb hard parts for 45 minutes in Berryman's before a solvent wash and careful re-assembly.
QUESTION: This was the first time (I'm pretty sure...) I removed this particular carb, and I noticed my (late-model 2001) float featured a bendable METAL tab instead of the fixed plastic float needle holder I was expecting. Has anyone else seen this on any PA carb?
Anyway reassembled without incident and it starts with 1 kick after 3 days now. Plus, no drips!
bonesv
Post by bonesv »
I’ve taken apart 20 or more pa carbs and never seen one with metal tab on float. Always plastic and one-piece even the older aero, spree and se/sb models.
The F9 engine was sent to me by 1Man8, with a totally believable 30 miles of use, from a 2001 SR like mine. Except for 9:1 gears, my ZX conversion and a Polini Contesta 72 top end, it is stock down to the air box and exhaust. Running a 90 jet. Tried a 92 and it fell flat on its face. Weird that I hadn't noticed the metal float tab. First one I've seen on any PA Carb too.
BTW I finally installed Noisy's Elite air filter. Fits perfect and a 20-MPH speed increase! :)
Wheelman-111 wrote: Wed Sep 05, 2018 10:51 pm BTW I finally installed Noisy's Elite air filter. Fits perfect and a 20-MPH speed increase! :)
Yes, but did you get the performance dual-density model? That's good for at least a bit more...
https://www.ebay.com/itm/142574702714
Scooter sat for 3 days, fired up with One Kick! That hadn't happened in months. Just cleaned and re-gasketed, also replaced cheap Chinese fuel line that had begun to turn mushy. Anybody got 5mm decent fuel line? I had to replace with a length of the same cheap material...
Also splurged on a new left side panel. Way too much money for what it is, but scooter is now Complete.
NoiseGuy's filters are awesome - perfect fit, light material holds oil without excessive drag on airflow. :worship:
Still going strong, with the only issue the following:
It's back to taking 10 or more kicks to fire up unless I start it about every other day. Apparently I misspoke a couple of posts above; 4992 miles on the odometer, about to turn 5! Iron Polini cylinder, still with (super-quiet) stock airbox and pipe. It chugs up to 50 pretty quickly and without drama. It'll run 55 if the wind isn't from dead ahead. It's been a good ride.
Jaygen
Post by Jaygen »
Wheelman-111,
Im running same bore and jet, stock carb, but 9:8:1 gears, I was wondering what contra spring your using?
Also are you still spinning 42g's in the variator?
2001 Elite SA50P
Polini Contessa
YMS V8 pipe
Malossi Fly clutch x/TFC bell
NYC 1000 RPM contra spring
Polini variator 5.9 Polini rollers
9:8:1 gears
Stock carb 90 jet
Been so long... no longer exactly sure. Mid-stiffness spring - I came up with a way to compare springs using a bathroom scale and a defined compression distance. Variator load feels like it's about 3 grams too light. Engine winds up higher, then settles down to torque peak, losing a half-second or so on the over-rev. I'll pull it apart and re-evaluate one of these days.
Carb Cleaning is Still Good Advice
F9 was becoming increasingly fussy to start, until the other day I couldn't get it to do more than idle at 1200. Any throttle caused instant stall.
Time-tested Board advice was put to the test again, this time with the assistance of 16 year-old Wheel-boy, who helped me reassemble after an overnight soak in Berryman's and a thorough spray-down with choke cleaner and compressed air. Wouldn't you know it? Fired up and purred. Wheel-boy, who just got his license, test-rode around the block, thrilled with good throttle take-up and power. Repeat it over and over; Clean the Carb!
That's an old pic, by the way, of 70-MPH F7's Fabrizi engine.
