Spree bbk issues.
Re: Spree bbk issues.
NO, using your pump and premixing at the same time will put too much oil in the motor and possibly lean your mixture out even more.
You guys are still using your cooling shrouds, right?
Of course . And I put the head on just like it shows in the owners manual.
When sitting on the bike that ledge where the cooling fins stick out is on my right where the.fan is
I put my head on just like this.....
Or did i mess that up too?
- 20160704_104638.jpg (100.57 KiB) Viewed 8178 times
I'm not sure, but that dont look right to me.
Bro that's 180 degrees out. Look close.
What do you mean? I should just flip it completely around right?? Just flip to the opposite side?
Ya I think that would be right. Compare the exhaust side in the pic and yours. Looks off haha.
- eclark5483
That's way off. Looks like your gonna need to tear it down and re-do it.
Dang. Well that was the culprit. I'm such an idiot
Hey I've done it too haha. Remember to reseal the head gasket w coppertex
I followed the Honda Spree Service Manual page 6-10...stop looking at a parts diagram for engine building tips, guys...seriously.
But that's how it should.be put.on.... I'll check the owners manual.again and see.
That parts diagram is accurate I think too
Ultraliner
Ughh balls really?! I'll have to pull the fan shroud and check mine but am pretty sure it's mounted in the same orientation as jakubmans pic
I seem to remember seeing obvious issues with trying to line up the fan shroud with installing the same way as the parts diagram says... Hella confused now?!?!
