1986 Tail Assembly, and wire harness
Posted: Thu Jul 02, 2009 10:22 am
by sectorhead
Two questions for you guys. Do they make an actual rear blinker assembly, or is it possible to use one from a different year? The second question is do u think that most the wiring harnesses i can find are that reliable? Thanks again for your help guys.
Re: 1986 Tail Assembly, and wire harness
Posted: Thu Jul 02, 2009 10:55 am
by toboggan
I know i have a wiring harness or two. let me look when i go out to my garage. shoot me a pm if interested!!!
Posted: Thu Jul 02, 2009 11:53 am
by bradthreee
Taillights from many other models should in theory work with your scoot, but the hard part is finding a way to cleanly mount them. Spree, for instance, you can adapt the 87 taillights on 84-86 without any modifications. They bolt on to stock locations and wire right up. For it to look clean I would also run the 87 rack as well.
