[b]'86 Spree - Have to partially cover carb to run/start[/b]
Posted: Thu Sep 01, 2005 11:59 am
by Kirby
I have to partially cover the carb to get the '86 spree to rev up and to run, will not idle. When I remove my hand the Spree will run for about 3 to 5 seconds before it wants to die, if I replace my hand it will again run. Any ideas?
Posted: Thu Sep 01, 2005 12:36 pm
by darat
yea air filter
Posted: Thu Sep 01, 2005 12:43 pm
by atomikpunx
too much air w/o the filter, extream lean state. not enough fuel, nor timing advance.
I'll purchase an air filter
Posted: Thu Sep 01, 2005 1:28 pm
by Kirby
I'll purchae an air filter and get back to you, thanks.
Posted: Fri Sep 02, 2005 9:18 am
by Justinsane
hehe, people have to realize that a stock bike should only be altered in the exhaust portion unless their going to upgrade plugs, jets, ect.
rock those air filters!
Posted: Fri Sep 02, 2005 9:56 am
by Kirby
basically what happened was the bike sat for years (only 175 miles on it), I cleaned out the carb and the air filter was rotten so I thru it away. I went to start it and the petcock was not working properly, I fixed that and when I started it ( did not attach the air box ) it ran poorly. The bike shop in town said they will have the new filter by Saturday. I let you know how it runs on Tuesday.
Posted: Fri Sep 02, 2005 10:39 pm
by eager_beaver
choke might not work
