Page 1 of 2
Spark Plugs - No Stores Have Em'
Posted: Wed Sep 07, 2005 11:05 pm
by Justinsane
whats goin on everyone.. im kinda desperate here.. ive had my spree for like a month.. and i dunno if it runs or anything... all i need is a spark plug... NO stores have them.. is there a website where i can score some?
thanks
Posted: Thu Sep 08, 2005 12:50 am
by burnt_toast
general stores like walmart wont have them, and any auto store will have to order them in.
best bet is to check honda dealer or some other motorcycle shop and they should have them in stock.
Posted: Thu Sep 08, 2005 9:18 am
by Justinsane
i found a place that will order them
but they can only order the BPR8HSA - thats the one for extended high speed riding - i think ill need the standard BPR6HSA . but no one has that on the inventory/order list
Posted: Thu Sep 08, 2005 9:40 am
by darat
they dont make that one anymore. y dont u step it up and get a split fire.
Posted: Thu Sep 08, 2005 10:59 am
by Davcon
darat, FYI the Splitfire plugs are just over-priced plugs that give only NORMAL performance. Have you noticed they stopped making thosse wild claims in their ads? They're not bad plugs, but they aren't any better than a normal resister plug. I have more info if you want it, but if there were any advantage, you'd find them at top levels of racing. They're not there.
Posted: Thu Sep 08, 2005 8:34 pm
by darat
yeah ok. thats y my spree ran better and gave me more top end.
Posted: Thu Sep 08, 2005 9:11 pm
by atomikpunx
maybe the previous spark plug was old, corroded, and needed to be regapped...?
Posted: Thu Sep 08, 2005 9:20 pm
by darat
ok what plug is at the top? because i would like to know
Posted: Fri Sep 09, 2005 7:42 am
by Davcon
There isn't one...................you're looking in the wrong place for extra performance. Atomikpunx probably hit the nail on the head.
Some plugs last longer than others, especially at certain heat averages. I suggest you use ANY good plug the equivalent of the BPR6HSA. Performance gains come from increased respiration, balance, compression, displacement, etc. We're just setting fire to gas here............................the brand of "match" doesn't make it burn with more power
Posted: Fri Sep 09, 2005 9:05 am
by darat
yeah better the spark the more it is completed the combustion so more power to the eng.
Posted: Fri Sep 09, 2005 9:08 am
by Davcon
All-righty then.
Posted: Fri Sep 09, 2005 10:30 am
by darat
think about it better the spark better power.
Posted: Fri Sep 09, 2005 12:04 pm
by burnt_toast
both of yall are right. a "performance" plug wont do much on stock application, but once ur tuned (bigger cyliner, pipe, etc) then you'll see some gains from these plugs.
Posted: Fri Sep 09, 2005 2:19 pm
by vette76
better throttle response/ get up and go.
Posted: Fri Sep 09, 2005 3:15 pm
by Justinsane
anyway i finally found a store that can order them.. thanks all
