Interesting problem...
Farfignugin
Post by Farfignugin »
My spree has seem to develope a strange fenomina (however you spell that word). It seems that it does not like the side panels, even with the nice air scoops. It will not run for more than a quarter mile (maybe even a tenth) and then it will just die. If I run it "naked" without the side panels, then it will run at least until I turn it off or it runs out of gas. Maybe something gets overheated under the panels? maybe it gets starved of air? maybe it just has a sense of fasion for running around naked? Any suggestions would be appreciated.
Thanks[/i]
vette76
Post by vette76 »
check for wire shorts. this happened to my elite and it was the coil wire shorting on the exhaust pipe.
87' spree (SOLD
12' wrx
Farfignugin
nope not a short there, there arent any wires running anywhere near something metal and everything is plugged in nicely.
vette76
Post by vette76 »
melted wires? loose coil wire?
87' spree (SOLD
12' wrx
Justinsane
Post by Justinsane »
maybe your spree is just a "free spirit" - aka nudist
burnt_toast
Post by burnt_toast »
what air scoops? too much air w/ a scoop could lean it out.
projects galore :nerd:
vette76
Post by vette76 »
scoops are for air flow. not intake. his scoops are not hooked into intake.
87' spree (SOLD
12' wrx
Justinsane
that is an interesting problem... haha geez
Farfignugin
there IS ONE wire that looks like it got cooked at the connector (somewhere underneith by the batt.) but my dad and I have checked all the wires and stuff and it all seems good.
Try a couple of things:
1) Clean your exhaust out. Might be plugged; plugged one's run hotter.
2) Check condition of engine fan
3) Run colder plug (NGK BPR8HS)
4) Check condition of shroud and spark plug rubber boot/plug. All in place?
5) Oiler working, and you're running injector oil?
Admin, Hondaspree.net
Farfignugin
Found out something a couple of days ago when makin a small trip...my bystarter o-ring wasnt sealing too great...so I put on a much thicker (at most 1/8 in. thick) and it works great now, it doesnt even die with side-covers on now 8). I also finnally reached 1000 on the odometer. YAY
