Looking for a performance clutch - 1986 Spree/NQ50
bjih_86
Post by bjih_86 »
Hi I'm new to the forum.
I bought a little red spree back in February. I fiddled with it for a while:
*derusted the tank with Evaporust (works really well) see: http://www.mopedarmy.com/wiki/Removing_ ... a_gas_tank
*changed the gunky fuel lines
*cleaned the petcock and in-tank screen.
*tried to clean the carburetor
I couldnt manage to tune it very well. Took it to the local shop - Paul and Chris at Atlanta Motorcycles and Repair - they did a great job: a carb clean, tune up and fresh tank of gas for $80.
It now seems that the clutch is giving up between 0mph and 10mph (0-16kmh). I know i can buy a stock OEM clutch, springs, belt etc online but I havent managed to find high performance parts or even determine whether other parts would fit an '86 Spree. I did a quick search of the forum and couldnt find much.
I would be grateful if someone could direct me to where I can find performance clutches online. Does Dr Pulley or MRP make clutches for the Spree?
Appreciate your help..
Thanks
bjih_86
Re: Looking for a performance clutch - 1986 Spree/NQ50
Post by bjih_86 »
So from my further research it seems that there are no aftermarket parts for the Spree.
If anyone knows otherwise let us all know.
Post by Kenny_McCormic »
Buy new clutch shoes and DIY, "dio" clutch springs(NOT center springs) fit and can be used to adjust engagement RPM. Also be aware that sprees normally can't get out of their own way till around 12 mph, where they hit the powerband and overcome the tall gearing causing them to take off.
bjih_86
Post by bjih_86 »
Thanks. The clutch was definitely slipping. A new clutch, belt and springs did the trick. It rides smoothly but yes the spree is pretty gutless between 0-10mph especially on inclines.
scooterwerx
Post by scooterwerx »
i used dio springs in my elite e when it was stock, made a huge difference in takeoff. the spree and elite e have basically the same setup...
Clivester
Post by Clivester »
scooterwerx wrote:i used dio springs in my elite e when it was stock, made a huge difference in takeoff. the spree and elite e have basically the same setup...
I thought the Spree has 3 clutch shoes, while the SB50 only has 2? :?
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
bjih_86
Post by bjih_86 »
Yes the spree has 3 tiny shoes, i dont know about the Elite. Do the springs still fit?
Lunytune
Post by Lunytune »
Is the whole assembly interchangeable? Which is best?
