The best methods of increasing power?
SpartanBurger
Post by SpartanBurger »
I have read a lot on the forums, but still can't find a definant answer on what are the best things to do to increase speed on a Spree. My spree goes around 29, and I have already done the obvious things, like cleaning the carb. I have also drilled the exhaust. But what other mods work the best? Any input is appreciated.
Justinsane
Post by Justinsane »
Alot of people here do the pully mod, intake, jets.. just explore this forum, it has all the answers
General Spree
MaskedJellybean
Post by MaskedJellybean »
What is the pully mod anyway?
MYSTERE1
Post by MYSTERE1 »
The pully mod is a modification made to the front pully. there is a full explination and how to in the Technical Documents section.
As far as which mods work best??? Well, I say that thay all work well in conjunction with each other. As for what to do next.... I would recomend the pully mod. Then get an aftermarket cone filter and re-jet the carb.
Hope this sets you in the right direction.
Mystere
1985 Honda Spree.
Front pully mod, 1" longer belt,
gutted pipe, K&N air filter, #80 main jet,
Intake mod, Leo Vince clutch springs,
40 MPH top speed.
MySpree
Post by MySpree »
GUTTED PIPE? MYSTERY EXPLAINE THAT TO ME.. HOW MUCH LOWDER?
Justinsane
calm down myspree.... put the caps away and come out slowly with your hands above your head. 8O
General Spree
Gruvin
Post by Gruvin »
best way to get more speed,
Only drive downhill.
1985 Spree Nq50 Special Edition
Mormonmopedmaifa
Post by Mormonmopedmaifa »
how would i go about guttin a pipe? im guessin with a cuttin torch but mine has sum oil on the end of it so its probly got suminside to . (FLAMMABLE)
Use the torch to clean it first, procedure in tech docs.
You can try drilling the exhaust; 4 - 1/4" holes in a circle around the out pipe, about 6" into the muffler.
Mormonmopedmaifa
wouldnt that make it a sh.. ton louder?
diomike
Post by diomike »
yes it will make it louder. but not too much
deathwish
Post by deathwish »
would gutting the pipe make the engine run lean???? or would u need to change jets or sumthing like that???
Drilling the exhaust doesn't seem to require rejetting. Check to see that you're running the #68 jet vs. #65, though. Iowa models have a #65 stock, I believe.
deathwish
Post by deathwish »
what if i just move the throttle clip down one notch
Mormonmopedmaifa
wheres the throttle clip?
