can someone help me??????
scout
Post by scout »
my spree is leeking oil into the crank case and wont let me start the scooter if i dont ride it alot
i dont know where the leek is cooming from and how to fix it
can someone give me some advice please and thank you
oliveskate
Re: can someone help me??????
Post by oliveskate »
scout wrote:my spree is leeking oil into the crank case and wont let me start the scooter if i dont ride it alot
I've kinda had the same problem before.
But some sort of liquid, or oil was leaking out of my carburetor, so try and check around there.
Just a suggestion.
JLLY.
89 SE50 A.K.A THE BEAST
Need a website made? PM me!
That is a symptom of a bad oil pump. On a Spree, it is reported that the seal between the pump shaft and pump body can fail, thus leaking oil into the crankcase. You can verify this by pulling out the oil pump with the input line intact. Place over a container for a couple days. If oil accumulates, the pump needs replacing.
Lunytune
Post by Lunytune »
I have a friend who complains that his daughter's "new" Spree smokes ferociously at times, and then runs clean. Would this be an indication of southbound pump?
If the smoking is worse the longer it sits, its likely the oil pump.
Post by Kenny_McCormic »
Gotta replace the oil seal on the pump.
