R/R Clutch
Shootin_Spree
R/R Clutch
Post by Shootin_Spree »
I plan to remove and replace the clutch this winter and I found the clutch and brake pads at Honda. My question is the manual lists a clutch tool 07725-0030000 that is $43.41 at Honda. Has any one made a homemade one or found somthing else that will work?
Jerry
vette76
Post by vette76 »
can u be more specific? if you are talking about clutch removal, hold the brake and loosten the nut.
87' spree (SOLD
12' wrx
Shootin_Spree
The tool is called Universal Holder. It can be seen on page 8-6 in the Spree service manual.
Jerry
eager_beaver
Post by eager_beaver »
you dont need that i took mine off just by unsrewing the nut
zoom
Post by zoom »
mines a whole differnt story. ive tried everythng to get tht nut off. sat ont he bike held the break and had a screw driver locking at and i would jump on the wrench and still nuthing with me.
maddog
Post by maddog »
use an impact gun!
An impact wrench saves a lot of time here. You can't hold the clutch using the brake. You can improvise a tool for this using a couple of 12-18" pieces of 1/2"x1/8" flat iron, with holes drilled in both ends. Bolt together one end to make a V, put bolts in the open end to hold the clutch drum.
