Tire replacement
Posted: Thu Sep 15, 2005 10:41 pm
by clint
Hi all
I had to replace my rear tire on my Spree. So I went down to the dealership to buy a set of 2.5X10 replacements. The guy at the store said that they cross over to an 80/90X10. I got home and mounted the tires no problem (I thought). When it came time to set the bead I run about 120psi the bead set, and I lowered the tire presser to 25psi as recommended on the tire side wall. Once I did this the bead slipped down on the rim and the tire doesn't sit right. Any suggestion? Also does anyone know where to get tubeless valve stems for these rims?
thanks
Clint
Posted: Thu Sep 15, 2005 10:45 pm
by vette76
CLEAN THE RIM BEADS, lubricate soap/water.
Posted: Fri Sep 16, 2005 6:55 am
by darat
i would go with a dunlop tire.
Posted: Fri Sep 16, 2005 7:42 am
by clint
I did clean the rim well and lubricated with silicone spray.
The tire brand is Chenetshin.
Mounting the tire is not the problem; it's just when I lower the tire presser to 25 psi as the tire side wall calls for the bead slips down and doesn't sit right. Any help would be great.
Thanks
Clint
Tubeless?
Posted: Fri Sep 16, 2005 8:13 am
by FredO
What is all the need for "lubrication" and silicon .... when change
tire? Are we talking about TUBELESS tires?
FredO
.....newBee
Posted: Fri Sep 16, 2005 8:43 am
by clint
Silicon spray is a lubricant and all it is used for in this case is to help the tire mount better
Posted: Fri Sep 16, 2005 2:23 pm
by vette76
yup. clean the tire off before riding tho so u dont slip. best way is to hold front brake and spin the tire.lol.
