how wide is the idle jet orifice?
thermarest
Post by thermarest »
I've soaked the carb for a couple of days and I'm trying to un-block the idle jet. It still seems blocked but I'm not sure.
Is it wide enough that I should be able to slide a needle all the way through? When it is clean will I be able to see a pin-hole of light through it? Or will it still look totally black? It seems to be really clogged and right now I think its the only thing keeping my spree from running...
burnt_toast
Post by burnt_toast »
yes, you should be able to see light through it, just a tiny opening.
I was able to slide some fishing line (or floss) through it, try that. A needle will probably be too big.
projects galore :nerd:
Try a #80 drill bit from a hobby shop as a last resort.
