how wide is the idle jet orifice?
Posted: Sat Sep 17, 2005 11:58 am
by thermarest
I've soaked the carb for a couple of days and I'm trying to un-block the idle jet. It still seems blocked but I'm not sure.
Is it wide enough that I should be able to slide a needle all the way through? When it is clean will I be able to see a pin-hole of light through it? Or will it still look totally black? It seems to be really clogged and right now I think its the only thing keeping my spree from running...
Posted: Sun Sep 18, 2005 12:37 am
by burnt_toast
yes, you should be able to see light through it, just a tiny opening.
I was able to slide some fishing line (or floss) through it, try that. A needle will probably be too big.
Posted: Sun Sep 18, 2005 8:48 pm
by noiseguy
Try a #80 drill bit from a hobby shop as a last resort.
