A happy side-effect of the Pirelli SL26 in the 90/90 size up front is that it almost perfectly compensates for Honda-sans hopelessly optimistic speedometer. Yup, 35 indicated was 34.5 on the GPS. Under 1.5% error, still on the safe optimistic side.
Tonight I installed the Polini 248-006 belt for Italjet and Derbi Vamos. 668x16.25. I incorrectly shimmed the front pulley boss 1.25mm and immediately hit a snag. When I started it the noise was immediately apparent: The kickstarter castles were just barely caressing each other. A temporary fix with a couple of washers between case and cover let me go out and test. I'll get and glue on a second gasket. Edit: The shim should go between the ramp plate and the boss, not behind the ramp plate.
Oddly, despite riding the very outer rim of the driven pulley, take-offs are not much different. Engine speed through the midrange also about the same. Seems to drop RPM a bit sooner as I approach top speed and may need lighter rollers to get over the top. However peak speed of 53.0 on the GPS was without trying very hard - better than the first-run 52.6 in Build Chronicles. Still running 340 at WOT, up to 375 when I let off.
