86 spree dying when going over bumps
tonrogs
Post by tonrogs »
Seems to try to die if not die when I go over bumps....It will lose power when going over larger bumps on the road and if I try to go through grass it wants to die.
Think this could be too much or too little gas in the float? I havent checked out the float yet and I know the previous owner had the chamber off it.
Justinsane
Post by Justinsane »
DEFINITLY a carb problem
take that sucker apart and clean it, make sure you have all the float assembly parts. i made this diagram for your assistance. good luck! any questions you know where to ask.
General Spree
Davcon
Post by Davcon »
Probably is the carb as mentioned. But check the easy stuff first. Spark plug wire..................wires to coil..................
Farfignugin
Post by Farfignugin »
mine does that too, i think it is just the fact that when you go over a bump the float goes up with the gas so it floods itself, therefore loss in power. The grass problem....ummm don't drive on the grass?
vette76
Post by vette76 »
check the coil/coil wires. it sounds like it misses right? check that.
87' spree (SOLD
12' wrx
tonrogs
Post by tonrogs »
vette76 wrote:check the coil/coil wires. it sounds like it misses right? check that.
It doesnt miss......seems like it floods out....
I checked the float and all and everything looked perfect...
Farfignugin
as i said...it might just be the float moving up with the gas in the bowl, making it flood. mine does that but after a sec or two, it goes back to normal.
tonrogs
Post by tonrogs »
Farfignugin wrote:as i said...it might just be the float moving up with the gas in the bowl, making it flood. mine does that but after a sec or two, it goes back to normal.
Ya....same. It will go back to normal, but it is quite annoying.
Mine does this too, worse if you're just starting out (like rolling out of the driveway.)
