Help: What Spark Plug and Battery to use?
andrewsilver
Post by andrewsilver »
I bought a used 1985 Spree yesterday, broken. It is missing the spark plug, battery and some other stuff.
Which spark plug do I need, BPR6HS or BPR6HSA?
Which battery do I need, YB4L-B or YB4L-BS?
Thanks in advance.
Andrew
Justinsane
Post by Justinsane »
theres different kinds of spark plugs for your spree that are available
Spark Plugs
NGK Brands
Standard - BPR6HSA
For cold climates - BPR4HSA
For extended high speed riding - BPR8HSA
The proper gap for the spark plug is .6-.7mm (.02-.03in)
as for the battery, im not too sure what the difference would be be..
heres a link to one of the most helpful sites for help
http://m.1asphost.com/spreerepairing/index.htm
General Spree
burnt_toast
Post by burnt_toast »
NGK BPR6HS
and standard atv size battery will fit a spree and most other scoots, @ walmart for like $20.
projects galore :nerd:
