Clutch issues?
Clutch issues?
I just bought a 1986 honda spree and I noticed that it didn't really engage the clutch very quickly. Acceleration from 0-8mph is really sluggish but then it takes off pretty well. Is this normal? Also, the clutch engagement speed zone seems to have acquired a problem in that it has started to * rather badly until the clutch engages and the whole thing takes off. I'm going to do some exploratory surgery soon, but I was just curious if anyone has experience with this. Thanks.
Re: Clutch issues?
Sounds normal to me. My 1985 Spree has been doing that since 1985. The Spree is really gutless until the engine gets quit a few revs on it. The * clutch engagement is not normal however. It could be a worn belt.
Re: Clutch issues?
I have the same problem with my nq 50 it really * until you get to about 10 mph then it runs fine.I have taken the clutch apart and everything measures in spec according to the manual,any suggestions.
Out-of-Round?
If measured precisely enough, there is no perfect circle. There's your *. Check that clutch bell.
