WILL IT WORK?
WILL IT WORK?
I NEED MORE HELP.
I JUST GOT ANOTHER 87 SPREE AND THIS DOES NOT HAVE AN AIR CLEANER OR HALF THE AIR BOX FOR THAT MATTER.IS THERE ANY WAY I CAN USE A VALVE COVER BREATHER OFF AN OLD CHEVY FOR AN AIR FILTER? OR WILL THIS AFFECT ITS RUNNING CONDITION TOO? THANKZ!
Dude, turn your caps lock off. No need to shout.
I've been wanting to try the Chevy breather thing. You have two Sprees? Try it on the one that runs and see how it works. If it does, use it on the other. The critical thing on the intake is the length of the rubber tube to the carb. Do you have that part? If not you could probably make something up with coolant hose.
Let us know what you find out, and how it impacts idle, wide open throttle, and part throttle response.
Just buy what parts are missing from drichardson@core.com or from eBay. When you complete it, it will run. You're going to spend a fortune to see that 'rigging' just won't work.
Scoot safely
- burnt_toast
I plan on trying the chevy breather idea as well. has anyone else tried it? if i get it, i will get the size 70 jet to compensate for the extra air, should that setup work?noiseguy wrote:Dude, turn your caps lock off. No need to shout.
projects galore
- MYSTERE1
- Goped
gutted my exhust, modefied the front pully, port and pollished intake. run on 94 octain fuel. or aviation fuel when i can get it. i'm looking into moding a polini race pipe to fit. other than that, i weigh 200 lbs. and it helps to give her a push from a complete stop to get her going. but hey, i keep up with traffic!
