87 honda spree Vacuum Issue
Posted: Sat Sep 12, 2009 10:23 pm
by clint699
hey,
i got a spree from a friend and cant get it to fire. i pour gas down the spark hole and it will sputter but i am not getting any gas to the carburator bowl? i have pulled off the vacum line and sucked and gas flows for a while but stops?
any ideas?
Re: 87 honda spree
Posted: Sat Sep 12, 2009 10:25 pm
by drizzle
...just gas in the spark plug, huh? you DO know it's a 2 stroke, right?
Re: 87 honda spree
Posted: Sat Sep 12, 2009 10:26 pm
One of two things, as long as the fuel flows from the petcock when you suck on the vacuum line, then the petcock is good. The other one is the float/needle valve is stuck in the carburetor.
Re: 87 honda spree
Posted: Sun Sep 13, 2009 12:08 pm
by clint699
thats great. thanks for the info. i will try the float needle next. i have the carb soaking right now. i will try try tonight and i will let you know.
i do have gas coming out the line when i suck on the vacum line. so thats not it.
but it seems tho ther is air coming out the nipple that the vacum line attaches to. should be sucking right.
Vacuum Issue '87 Spree
Posted: Sun Sep 13, 2009 12:38 pm
A pull on the petcock line should draw the diaphragm down to open the valve. Capping the line (or plugging it with your tongue - eek!) while under vacuum should keep that flow going indefinitely. If that's where your "air is coming out", then there's a pinhole in your diaphragm. Relace if so.
If you mean the 1/8" metal hose barb at the manifold is expelling air instead of sucking, there is an in/out rhythm to it, but the net result should be vacuum. If not your reedvalve isn't sealing or there's a gasket gap somewhere.
Re: 87 honda spree Vacuum Issue
Posted: Sun Sep 13, 2009 1:40 pm
by clint699
yes yes. thats it... the manifold nipple thingy.... thats it...ahhhhh finally someone who knows what im talking about....hallliluyya
THANK YOU VERY MUCH...
i will try the things you posted.
smiles smiles smiles
Posted: Sun Sep 13, 2009 1:44 pm
by clint699
could be the reedvalve? if there is a gasket leak somewere...what gaskets should i check? could it be the side cover? i know i will need one of those..
