There may be much discussion as to how much carb it will take to feed the Tazland bore's modest appetite for fossil fuel, but this is certain:
Whatever carb you procure will need to be tied into the case port somehow. Most aftermarket big carbs use a 31mm spigot mount that clamps into an aftermarket intake/reedblock assembly, the "CT" being a very popular version. The Spree 2-bolt intake manifold/reed mounting isn't compatible with any of these.
NoiseGuy was selling a slightly bigger SB50 case reed assembly, which may be a worthwhile upgrade if you're trying to go bigger on the intake side. People have reported using the Tazland-supplied jet (a #95) and Honda's own 78, and lots in between. I haven't read any hard results, but I speculate that 78-82 would be about right for the stock carb.
Arreche carbs sold at Scooter-Center.com use the same flange-mount and bolt spacing as Honda. There is a very good 17.5mm that had enough CFM to feed 65cc Flash I to beyond 55 MPH, so that may plenty for the big-bore Spree as well. The Arreche uses the stock bystarter and connections. Fitment of the stock airbox may be possible; the carb is dimensionally similar to the stock Keihin. However it does feature replaceable pilot jets, and that may open up different air filter options. There are different needles and emulsion tubes as well for lots of Tuning (and tuning
error) Opportunities. The carb bellmouth fits 1" filter donuts. Search Honda "Vision" on the ScooterCenter.com site. Unless you're fluent in German, click on the Union Jack flag.
As you enlarge the intake side, the Spree's limiting factors shift elsewhere. The pipe is an almost certain barrier to high (power-producing) RPM. If you enlarge the pipe, then the small transfer and boost ports emerge as an issue. One thing's for sure: You can't assume world-beating power just by throwing on a big carb.
Please let the Forum know your decisions and outcome?
