1984 spree labor of love !!!!!!!!
this is my first major rework. Its been a great way to get my head around the concept of 2 stroke (I've been on 4 strokes for 25 years) so I have a pile of parts from craigs list.
http://farm3.static.flickr.com/2543/394 ... 3286bd.jpg
I 'm not gonna post much till i can fig out how to embed pics
Re: 1984 spree labor of like
The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side.
Hunter S. Thompson
1987 NQ50
Hunter S. Thompson
1987 NQ50
Start with that deep fryer and get some food, looks like ur gunna need it!mkluvin wrote:where to start
2 frames? You plan on building 2 or one spree?
Looks like you have alot of work to do
What parts are you missing?
'98 Yamaha Jog Cy50k
'96 "Frankenstein" Japanese Jog Cy50
well first I found a good lower end ( crank case and drive train) in all this mess then found that I had 3 bad cylinder sleeves ...mmmm what to do
so I got on line and lucky me I found this forum! I also found out that the rebuild of the top end would cost a small fortune if i went to Honda
sooooo I jumped on e-bay and what do you know I found the 44 mm big bore kit (comes with 44mm piston w/rings and sleeve, piston pin and sir clips top and bottom gaskets, also a jet (the size was not specified). I paid the 100 for the kit and 10 for S&h on a thursday night and it was at my house monday when I had gotten home from work
It came with a bit of instruction and the # and address of a person who could mill my head to fit if I chose to send it out(the head must be milled to the larger bore)
his name is tobbogan on the forum (awesome guy!)
so I went to work on the parts I had just cleaning and putting a few coats of paint on the lower unit, tested the starter and and choke(10 ohms on the multimeter)
I'm leaving the stock belt on till the break-in is done then I'll move up to a 1/2 x 24
and heres what I have so far . not to bad for a wire wheel and a steamer
I'll put pics up with the head soon ( it came back looking like it was just out of the box ) great work Tobbogan!!
yeah I've got ocd
but I dont have rear plastics so I really wanted it to look as good as it can
anyway I figured it would take 3 times as long as it did for the engine to come together so I stripped the entire frame down for a good de-smegg and a paint job. I'm talking all the way down! there are no to pieces bolted together, It was also a good chance to give the wire harness a good once over
most of the plastics have been painted and I'll have pics next post.
yeah I've got ocd
Sorry Props to taz on the big bore
I have most of the parts I need I think I'm missing the rear plastics and the tail light rack but I'm thinking about making some hard side cases(I have them on my bmw motorcycle and love them..these would be most likely ammo cans or the like some thing easy to work with and that I can mount some turn signals into.
Any semi competent machinist can mill a head.
I understand that. thats why I had someone else do it. I have no mill or skill.
getting there
most of the paint is done on the frame and engine I used automotive primer and a protective enamel . the plastics got rust-olium plastic primer and some hunter green.
I would like to put a few rally stripes on it then a 84 in a circle like the old lil MG cars. but with the green i half tempted to go with a john deere logo.
why green ? how many green sprees have you seen. that and my son has a red razz
- bradthreee
Really nice work Mclovin!
You'll totally be able to pick up hot red heds and tell them what time it is....
Nice brad.
I've seen that motor in person, and let me tell you, the paint looks superb!!
And thanks for all the kind
mklovin (i saw that emoticon and had to use it)
Can't wait to here it run! and see the final stage!
Well , I was up till 12 last night but I have it pretty well done with the parts I have (no back plastics or rear cargo rear signals rack or mirrors)
I am very happy with the color scheme. I painted the the whole frame black and the rims as well since I blacked out the crank and housing. This seems to down play the lack of plastics. I'm still not sold on what kind of rally stripe to go with ...or john deere symbol..he he he . I'm in the process of dialing in the new big bore. I'm just waiting for some jets so I can try a few setups..wow what a fun week. started on a Sunday finished on the following Sunday.
BTW MY STARTER DOESNT HAVE A LOT 0F SPEED IS THIS COMMON.and will it reflect in my spark?
my sons razz zings
thanks for looking!
my sons razz zings
thanks for looking!
- bradthreee
well she's about done, It's time to bring everyone up to date What we have here is a 1984 spree nq50
THE GREEN HORNET 34-35 mph he he he for now!
getting decals made!!!
whats been done -
tazlands 44mm big bore <--------- fantastic
head milled to big bore spec<-----------great job done by toboggan
95 jet in carb - 5 -1/2 inch holes in the top of the air box
opened more volume in the top of the intake by grinding out some material
stock pipe went through a cleaning by wood stove--get it real hot and remove from the stove TAKE OUT SIDE and blow air from a compressor into one end and the rush of air will burn a lot of carbon out - reheat and blow in the other end do this till you feel that its lost some carbon. I tap it with a screw driver it should sound tiny if it sounds like a thud it could be more carbon
replaced the side cover with a kicker cover from and 86 ......be careful if you buy on ebay the kicker sides don't ever seem to be sold with the kicker flywheel and its a must!!!!!!!!!!!!!!!!
starter and bendix from the 86
tazlands big bore gave great torque so
shaved the front pully (used a 86 it has more meat on it )I added 1 washer on the front of the flywheel (this mod also helped my starter catch better as it brought the flywheel closer to the bendix)
went to a 1/2 - 25 gates green kevlar belt
tazlands big bore gave great torque but if you don.t feel you have the power try the belt first its 12 bucks. I have a lot of pulleys so i didnt mind cutting one . I love the having both. with 2 belts -one new stock and the gates upgrade and 2 pulleys one stock and one milled there is a lot you can do to the power curve ... but first have your suff tuned in. the results will be worse if you cant make good power
BELT!!!!
I had a worn belt and was getting 27mph after the belt and pulley mod i was up to 34-35
new battery
massive repair and re-tape of the wire harness
complete strip to the frame and repaint frame, rims and forks w/protective black enamel forks bearings removed and repacked
remove stock pet * and then went to pre mix 32:1 after break in. connected both ports on the intake together wit a short tube. why waste vacuum on opening the diaphragm now i use the oil tank as a reserve tank
no back plastics so why have fronts
chopped the back fender (i love It)
the front is next for reworking !
whats up next
new tires - I'm going to 10x3 street tires
custom turn signals
hard removable saddle bags
new seat
tazland's new gears when the money's there
port the exhaust
AND
using the expansion pipe calculator make a pipe
I have a guy at work doing up a .cad file for the patterns to mark and cut for roll/weld your own pipes base on stock bore + 15mm2 removed in material removed in exhaust porting the stock port size is 225mm2 so I went 240mm2 thats about 2mill by7 mill removed
so I hope to have at least a pdf for a untested pipe to offer up soon! this is a sore spot for me as spree pipes seam to be on the minds of owners, And with bore and gear kits there to provide more breathing in and out of a engine that was restricted to start with. I would like to see a pipe for the 44 -47 mm kits as people who spend to upgrade will spend to up grade !!
Ill let you know how the new tire roll. 2 mph faster is great when you needed new skins anyway
thanks to all who gave me hope and good advice!! this groups is the bomb ..i've looked at some honda express forums and found no where near this much great help
I much to learn
thanks
mkluvin
whats been done -
BELT!!!!
new battery
whats up next
custom turn signals
new seat
port the exhaust
AND
I much to learn
thanks
mkluvin
