battery
Mormonmopedmaifa
battery
Post by Mormonmopedmaifa »
ok my battery is currently dead and im gonna charge it. once its charged will it hold a charge for a long time like a car. i guess what i mean is dies this have like and alternetor or something so it will charge.
M>M<M
the mormon moped mafia strikes again!!!!!
Justinsane
Post by Justinsane »
from my experience, if the battery is shot, it will hold a 12 volt charge for like 20 minutes, the alternater will power the scooter while its running, but when you try to start it, your most likely gonna have to jump it.. i suggest saving yourself the trouble and buyin a new battery.
General Spree
maddog
Post by maddog »
Most batteries will last 2-3yrs. if you get a new one buy a trickle charger, this will charge it slow instead of a fast charge which most moped shops do, it only melts the lead plates together.
Justinsane
im a tad bit worried myself, i spent 30$ on a brand new battery, and accidentally charged it overnight on 6V then the next morning i switched it to 12V for a few hours, i hope this wont affect it badly..
even though i tried to start it for few minutes and it started slower, and slower, until it was just a click and i had to jump it....
General Spree
burnt_toast
Post by burnt_toast »
Justinsane wrote:im a tad bit worried myself, i spent 30$ on a brand new battery, and accidentally charged it overnight on 6V then the next morning i switched it to 12V for a few hours, i hope this wont affect it badly..
just charge it overnight again on a 12v trickle charge, that outa do the trick.
projects galore :nerd:
Mormonmopedmaifa
ok
i thought these were six volts and u had to charge em with a motrcycle charger? and general sree i saw ur neon link how do those run off a moped system it seems like ud need a computer power supply slapped on sumwhere.and my battery is only about a yeaqr old its just been sittin in a garage.( sum guy took my spree to a repair shop and left it there after they fixed it and put a new belt and battery in it and got it for 150!!)
vette76
Post by vette76 »
these are 12v systems. u do have a 12v batt rite?
87' spree (SOLD
12' wrx
Mormonmopedmaifa
umm yeah i dont know what my battery is . i can tell you this .... its a pretty small battery about 5-6 inches long and 3-4 tall.it has yellow plugs on it and a green and red wire . if that helps..... somebody told me i had to pull out the little yellow plugs when i charge it is that true?
vette76
Post by vette76 »
pull out the plugs and make sur it has aic in it. it should say on the batt if it is 12, 6v
87' spree (SOLD
12' wrx
- 6V won't hurt a 12V battery, but won't charge it either. Might run it down though.
- If you have 6 little holes on top, it's 12V (about 2V per cell). If you have 3 it's 6V. Only Harley (and old ones) to my knowledge use these. Very rare.
- 500 mA will charge the battery over several hours. 1.5 - 2 Amp will charge it in about 1 hour, and can overcharge it at that amperage. Look at the charge amperage rating when you use it.
Admin, Hondaspree.net
Mormonmopedmaifa
what happens if i overhcarge it?
