elite sa50 oil
nwaman22250
elite sa50 oil
Post by nwaman22250 »
i bought a 99 elite sa50 and when i took the head off and turned the motor to drain all the oil out it was a real thick oil
that looks like it is made to mix not inject is there a certin kind of oil i should get also whould running a thick oil cause the scooter to not run right
thanks
novs86
Re: elite sa50 oil
Post by novs86 »
2 stroke injector oil from a Honda dealer is best but if you need other options this is a good second choice.
http://www.castrol.com/castrol/sectiong ... Id=7040924
I'd rather be riding my Aero!
bakaracer
Re: elite sa50 oil
Post by bakaracer »
If you want a oil that doesn't leave to much carbon behind.use the belray si7,yamalube 2t, or motul 710.All of these you can use in the stock oil injector.
Lunytune
Re: elite sa50 oil
Post by Lunytune »
nwaman22250 wrote:i bought a 99 elite sa50 and when i took the head off and turned the motor to drain all the oil out it was a real thick oil
thanks
Most likely, the bike had been sitting in storage for a while and the high volatiles had evaporated off, leaving a thicker substance. Premix oil is not noticeably thicker than injector oil.
