spark plug for a 94-01 dio motor
ok this is my question i am running a 72cc big bore kit and was wondering what u guys are using for a spark plug . brand and part number thanks rob
2001 honda elite s 50cc
1995 honda elite s 72cc
Re: spark plug for a 94-01 dio motor
i recommend a B9HS to start.if it fouls go down to an 8.
got big main?
for long as i can remember
im running a 88 jet in it with stock gears and muffler
smaller the number hotter plug or colder plug ?
smaller number= hotter range. yes.
a pipe will reveal some "hidden" power within that big bore kit!
add a 108+(ish) main+ 1 oz of oil to the fuel tank.
if in doubt ask one of the resident experts.
pipe and gears are going in this winter for next year
- tazland001
That is easy. The NGK BPR6HS is the plug for you. I used these in the las vegas heat at my shop and never had any problems on my 50mm kits.
marc
marc
That plug number is for the stock bore not big bore kits.tazland001 wrote:That is easy. The NGK BPR6HS is the plug for you. I used these in the las vegas heat at my shop and never had any problems on my 50mm kits.
marc
in the summer run the b9hs and winter run the bpr8hs.If you can't get the b9hs the bpr8hs,bp8hs or b8hs is ok.put a little oil in the gas tank.about a cap full.Rob wrote:ok this is my question i am running a 72cc big bore kit and was wondering what u guys are using for a spark plug . brand and part number thanks rob
- burnt_toast
B8HS in every one of my dio builds, also what all hawaiins recommend, cant go wrong
dio head chamber uses side sparkplug location which is not very sensitive to heat range plug anyway
for jog style b9hs is way to go..
projects galore
thanks for all the help guys i will go will the b8hs and see how it runs
- tazland001
I have used the BPR6HS in all my upgrades and my customers upgrades. And yes I know it is the stock plug. They dont foul so I stick with stock. Got a problem with that
hehhehe.
Please do tell what is the big difference between the two plugs besideds hot or cold. Cant wait to hear this one. If aint broke why fix it?????????? I am all ears..
I wish we could all get together and race our elites against eachother. We need a scooter convention. yahh baby. Should I post pictures when I upgrade my piaggio typhoon? got a 90cc kit to install with a expansion chamber muffler. That will be loud!! And easy...
Marc
Marc
