spark plug for a 94-01 dio motor
Posted: Mon Oct 19, 2009 6:39 am
by Rob
ok this is my question i am running a 72cc big bore kit and was wondering what u guys are using for a spark plug . brand and part number thanks rob
Re: spark plug for a 94-01 dio motor
Posted: Mon Oct 19, 2009 9:25 am
by mookie
i recommend a B9HS to start.if it fouls go down to an 8.
got big main?
Posted: Mon Oct 19, 2009 9:29 am
by Rob
im running a 88 jet in it with stock gears and muffler
Posted: Mon Oct 19, 2009 9:35 am
by Rob
smaller the number hotter plug or colder plug ?
Posted: Mon Oct 19, 2009 9:37 am
by mookie
smaller number= hotter range. yes.
Posted: Mon Oct 19, 2009 9:40 am
by mookie
a pipe will reveal some "hidden" power within that big bore kit!
add a 108+(ish) main+ 1 oz of oil to the fuel tank.
if in doubt ask one of the resident experts.
Posted: Mon Oct 19, 2009 9:46 am
by Rob
pipe and gears are going in this winter for next year
Posted: Fri Oct 23, 2009 7:15 pm
by tazland001
That is easy. The NGK BPR6HS is the plug for you. I used these in the las vegas heat at my shop and never had any problems on my 50mm kits.
marc
Posted: Sat Oct 24, 2009 1:40 am
by bakaracer
tazland001 wrote:That is easy. The NGK BPR6HS is the plug for you. I used these in the las vegas heat at my shop and never had any problems on my 50mm kits.
marc
That plug number is for the stock bore not big bore kits.
Posted: Sat Oct 24, 2009 1:43 am
by bakaracer
Rob wrote:ok this is my question i am running a 72cc big bore kit and was wondering what u guys are using for a spark plug . brand and part number thanks rob
in the summer run the b9hs and winter run the bpr8hs.If you can't get the b9hs the bpr8hs,bp8hs or b8hs is ok.put a little oil in the gas tank.about a cap full.
Posted: Sun Oct 25, 2009 1:56 am
by burnt_toast
B8HS in every one of my dio builds, also what all hawaiins recommend, cant go wrong
dio head chamber uses side sparkplug location which is not very sensitive to heat range plug anyway
for jog style b9hs is way to go..
Posted: Sun Oct 25, 2009 6:34 am
by Rob
thanks for all the help guys i will go will the b8hs and see how it runs
Posted: Sun Oct 25, 2009 1:04 pm
by tazland001
I have used the BPR6HS in all my upgrades and my customers upgrades. And yes I know it is the stock plug. They dont foul so I stick with stock. Got a problem with that
hehhehe.
Please do tell what is the big difference between the two plugs besideds hot or cold. Cant wait to hear this one. If aint broke why fix it?????????? I am all ears..
I wish we could all get together and race our elites against eachother. We need a scooter convention. yahh baby. Should I post pictures when I upgrade my piaggio typhoon? got a 90cc kit to install with a expansion chamber muffler. That will be loud!! And easy...
Marc
Posted: Sun Jun 23, 2019 5:54 pm
by CitoZx50
yes!!!! We need a scooter drag race athon lets start it up 2019 Scooter Olympics
