Need expert help
Posted: Mon Oct 19, 2009 10:52 pm
by roadie114
Ok guys, I have an '87 Elite 80 that came with tubed tires. The rims are stamped tubeless and can run them, so I purchased 3x10 tubeless tires. Now I just need to know what size tubeless valve stem to purchase that will fit. Any ideas? I called my local Kragen and they carry two sizes, .45 and .6. No idea if those are compatible. Any help would be appreciated, thx!!
Re: Need expert help
Posted: Mon Oct 19, 2009 11:40 pm
by mookie
there is a lot i don't know but can't you go to a bike shop and simply but tubeless stems.have the shop measure if there is a question about what to use.
are you going to put the tires on yourself? if not let the shop get the tire to hold air...
Posted: Mon Oct 19, 2009 11:44 pm
by chevyguyjay
go to murrays, or autozone. they sell valve stems there. i did that to an elite 80 i worked on a few months ago. its like $6 for a package of 4.
Posted: Tue Oct 20, 2009 11:15 am
by roadie114
Sweet, thanks guys!!
Posted: Tue Oct 20, 2009 11:42 am
by roadie114
chevyguyjay wrote:go to murrays, or autozone. they sell valve stems there. i did that to an elite 80 i worked on a few months ago. its like $6 for a package of 4.
Do you remember what size you purchased?
Posted: Tue Oct 20, 2009 12:03 pm
by Alarmnbob
Measure the hole in the rim. The valve stems go by hole size. 11.3 mm is standard for my 125 Elite and Helix
I would believe it to be the same on the 80cc. 11.3 mm is .05 inches so either .45 or .6 with a good rubber seal will work as long as it fits the hole.
Posted: Tue Oct 20, 2009 4:21 pm
by roadie114
Alarmnbob wrote:Measure the hole in the rim. The valve stems go by hole size. 11.3 mm is standard for my 125 Elite and Helix
Found Slime ones at Autozone so I purchased both sizes.
Posted: Tue Oct 20, 2009 4:26 pm
It seems to me there'd be a good living to be made selling valve stems that have a 90-degree kink in them so that gauges and fittings can be applied to the valve without having to clear the wheel hub. My front tube has such a valve, but my tubeless rear Met wheel does not. If the valve stem protrudes much more than a half-inch, it's hard to attach the pump. Links, anyone?
http://www.prestigewheel.com/Image2994.asp
http://www.oldbikebarn.com/K-L-Tire-Val ... nda-Street#
Posted: Tue Oct 20, 2009 8:14 pm
by mookie
Posted: Sat Nov 21, 2009 3:09 pm
by mcbridew
I was looking to change my oil in my 87 Elite scooter and opened up the wrong screw on the bottom. It is a bolt with a long spring and then a round like cylinder. I need to find out how to put it back in. In what order.
Posted: Sat Nov 21, 2009 8:01 pm
by veedubh20
you can go to any tire stores, and employee give free stems
I got from lex brodie tires
Posted: Sat Nov 21, 2009 10:02 pm
by bakaracer
I got these for sale.they are anodized
Posted: Mon Nov 23, 2009 4:59 pm
by bakaracer
Wheelman-111 wrote:Greetings:
Did you find those 90 deg vales yet?
Posted: Mon Nov 23, 2009 10:09 pm
by maddog
you can get a smoother ride if you run tubes.
Posted: Mon Nov 23, 2009 11:24 pm
by maddog
and you can get tubes in both 90 deg. long & short stem
