rumia 51 mm big bore kit
Rob
Post by Rob »
was wondering if anyone has used this kit?
do u have to do any mods to the case for this to work or is it a bolt in deal ?
2001 honda elite s 50cc
1995 honda elite s 72cc
Re: rumia 51 mm big bore kit
Stickied for your reading pleasure:
http://www.hondaspree.net/phpBB3/viewto ... =4&t=10128
Look in Limp1944's posts for links to installation, etc. Not all his assertions are supported by later facts, but as they say,
"Parts is Parts". Tuning is the greater determinant of success than initial quality of manufacture.
burnt_toast
Post by burnt_toast »
better off with 47-48mm kit for daily/street riding, as far as long term reliability goes
but for max cc gains on stock crank without stroking, the 51 kits pack a nice punch
I should be stocking both kits soon I hope, and will help with tuning advice :2thumbs:
projects galore :nerd:
Rob
Post by Rob »
besides ordering from limp who else sells rumia products i cant find them anywere else
Not Ruima, but VT has a couple of 50mm cylinders for SA16:
http://www.vtcycles.com/vtc_plugins/zog ... =52&cat=11
The cylinder skirts on the 51 approach critically thin, but some have reported good results. For whatever peroformance increase 1mm brings, it might be safer to go with 47-50 for durability. VeeDubh has recently asserted that the 47mm Corsa is very hard to beat, whatever larger bore you select.
burnt_toast
Rob wrote:besides ordering from limp who else sells rumia products i cant find them anywere else
Rob, check out:
viewtopic.php?f=4&t=11971
I should be carrying Ruima parts pretty soon. As an alternative MRP offers a 48mm cast iron Dio style big bore kit which is very similar, check it out in the Dio parts section
http://scootspecs.wordpress.com/
veedubh20
Post by veedubh20 »
Some big bore kit are not bolt on, Need to porting on on the case. Just beware by looking at base gasket.
2 bolt on bore kits are contesta and corsa. No case mod need! :mrgreen:
here are some pics you need to decide.
50mm taiwan cylinder. stock honda base gasket is block boost port.
stock gasket has mark by black pen. need to cut boost port, block air travel.
Image this is stock block untouch.
Image taiwan 50mm piston -cylinder jug.
here is the base gasket, there are 3 lines by blk pen. need to do case work.. Once the case is cut, then cant go back, just have to run 72cc malossi bore.
Polini contesta 72cc is very good street bore kit and reliable. Ready to bolt on. Must run good synthetic oil. 32:1 premix. Corsa is for racing bore and very fast!, bolt on
Rob
Post by Rob »
didnt realize u had to cut the case
so that is not something i wanna get in too
thanks for the good info and pictures well explained i may say
