I worked last night till 12:00 Installing the 70cc kit and speed variator and jet on my aero 50. Well I got home from work today and finished up a few things I had to do yet, I hit the starter and it fired right up within 1 second and ran perfect. Sounded really deep and throaty too. I let it idle for a while, and took it for a spin. All I can say is WOW!!! This thing takes off like a rocked. at least 3 times as fast as before with the old engine! I am really inpressed. I didnt top it out, cause the book says to break it in for 300 miles before driving normal, but I hit 39 and it was still climbing fast but I let off. I cant wait till I get it broke in and see what she'll do. Its funny, going 35, the engine sounds as if it is doing 15, cause the rpms are so much lower. I am also going to put some better springs in the clutch. Too bad the bike looks like shizz cause I have none of the panels painted and on the bike yet, but what it does have on is all painted and clean
I have some questions though. I am sure that the fuel/air screw will have to be set different now, but when I first hit the gas, it spits a bit, then flies, and if I am at about half throttle, and slam it to full, it burps a bit then flies. I am sure this is a carb adjustment, but I dont know what.
Also one of the long lower hoses on the carb is dripping gas, I am not sure what one, but I completly cleaned the carb too, and this is the carb off my other aero, which never leaked gas. Is it leaking because my fuel valve/shutoff is broke, or a problem in the carb? if so how do I go about fixin it? it sux cause the gas eats at the brand new paint on the case.
Thanks For all your guys help. I really appreatiate it.
