I need some advice for my spree
1987 Honda spree
Ok so on my 1987 Honda spree I'm going to put an 85cc 2stroke dirt bike pipe on it expansion chamber and all will it work be sum advice
Re: I need some advice for my spree
heap bigum trouble kemosabi, cant tell what smoke signals say!
Greetings
Methinks it will run, perhaps just not all that well. If you're just replacing a rusted-out stocker, it may be worth doing just because it's handy and paid-for. If you seek performance gains, you will need to do a bit more reading. Unless you have already adapted the header to the M/C chamber, it'd probably be easier and a whole lot less work simply to locate a nicer/newer stock pipe. The Elite ES pipes should fit and are reportedly an upgrade for the Spree pipes. They turn up frequently on eBay and here.
