Marine oil
- Mormonmopedmaifa
Marine oil
ok i just read that marine oil will jack everything up. could this be why i know need a new head gasket? ive been using blue 2-stroke marine oil for the whole 3 weeks ive had my moped and its been runnin fine it just goes through the tank real slow. like i could easily get 3-4 tanks of gas out of one tank. ummm is this really bad?
Drain that marine oil out and put in some quality injector oil.
Your going to get alot of headaches by running the marine oil. You will probably end up with a plugged muffler and nasty amounts of carbon buildup in your engine. Do it before you cause more damage to the engine. I buy oil at a local scooter shop that is made just for injector systems on mopeds and scooters. Its about 6 bucks a quart but it saves alot of headaches down the road.
Sounds like your usage is about right. Get that marine oil out now; it make a real mess.
Admin, Hondaspree.net
