CHARGING SYSTEM TROUBLESHOOTING
The home of the FAQs and all the things you need to know to fix your Spree / Elite, outside the service manuals
Moderator: FAQ Moderator
Locked
darat
Post by darat »
Charging system
*No power-key turned on
-Dead battery
-Disconnected battery cable
-Main fuse burned out
-Faulty ignition switch
*Low power-key turned on
-Weak battery
-Losse battery connection
*Low power-engine running
-Battery undercharged
-Charging system failure
-Lose connection or short circuit in lighting system
*Intermittent power
-Loose battery connection
-Loose charging system connection
-Loose starting system connection
*Charging system failure
-Loose broken or shorted wire or connection
-Faulty voltage regulator
-Faulty alternator
Locked
